Engine oil ?
Hello pls need help to pick a good engine oil for my B20vtec turbo car the option Y have are : Lucas oil 20-50 , Castrol 5-50, Eneos oil 0-50 or 15-40 , Redline 15-50, Shell Ultra 5-40 , Mobil 1 15-50
Witch of this oil will be the best for my car where I live there is no winter and is really hot place. My car is doing 500whp and rev to 9000 rpm |
Re: Engine oil ?
Mobile 1 15-50.
Re: Engine oil ?
brad penn 20w50 :thumbup: http://t1raceparts.com/en/products/d...acing-oil.html
Re: Engine oil ?
Originally Posted by jdm inc
(Post 41119727)
Re: Engine oil ?
I really like the Eneos 0w-50. That's what I use in my 600 whp Integra, revving to 9200 RPM.
Re: Engine oil ?
Depending on the use of the engine but for a street car I would use a 10w-30 after that is just a matter of brand pref. I like mobil1 and Royal purpple in my modded engines but if it's just the DD then I use mobil5000. The only time I would use above a 10w-30 is for a race only engine but even then I would only use a 15w-40.
Re: Engine oil ?
Originally Posted by civic_r87111
(Post 41132416)
Re: Engine oil ?
Well think about the purpose of the oil.. To lube and cool! What is hondas recommended viscosity (10w-30 in most engines, never above), y is that the recommended viscosity?? Because of the clearances of the oil passages! There is no real gain behind using a thick a$$ oil besides a high oil pressure. It doesn't lubricate or cool any better nor does it stop oil consumption. Just because ur oil pressure is higher doesn't mean it's working better either, it just means it's harder for the oil pump to pump it. I'm more interested to hear y u guys think it's better to run such high viscosity oil..! Remember ur not driving old fords or chevy's with sloppy lose tolerances.
Re: Engine oil ?
Brad penn racing oil 10w30 offered by t1 racing. 20w50 for a looser motor 10w30 for a stock clearence motor. Thats my 2 penny's
Re: Engine oil ?
^^ pretty much, the only time I would use a 20w-50 would be if I set my bearing clearances to .0025".
Re: Engine oil ?
(Post 41132416)
Re: Engine oil ?
I'm not sayin it will absolutly cause problems but it doesn't benifit anything either.
Re: Engine oil ?
I hear ya. Im trying to figure out what I want to run in my next build. Im not sure if I want to keep it that thick
Re: Engine oil ?
brad penn 10-40 race.
| All times are GMT -8. The time now is 10:07 AM. |
