emissions inspection - hondata to obdII
ok. i think i have my overheating issue resolved. hope you guys can help with this one. I have emissions inspection due this month. prob is i converted my 00 lude to obd1 + hondata. for emissions, i need the stock ecu. prob is its a throwing cel. misfire. i have lowered compression, greddy kit, and 370cc injectors. i have a set of gsr injectors available. can i just clock the dizzy advanced and try the gsr injectors? any advice???
Re: emissions inspection - hondata to obdII (eggie75)
noone has had this problem?
Modified by eggie75 at 9:41 AM 10/24/2006 |
anyone?
w/ the p13 ecu there is noway the 240 gsr injectors are going to cut it...
pull everything out and go back to stock fuel/ecu and then figure out why its kickin a cel and fix that....and dont boost because soon as you do itsa gonna kick a cel for positive pressure at the map sensor |
