emanage install *searched*
im putting a 19t greddy kit in my 98 dx coupe...the instructions (which im sure a lot of you know) are terrible (not to mention that they are for an ex not a dx)...so i was hoping someone could explain to me what i need to do to install this.
thanks in advance
thanks in advance
Re: emanage install *searched* (alacard)
Is this what you were given
http://www.mohdparts.com/emana....html
This site i listed below also makes a Wiring Patch Harness.
http://www.autosportwiring.com/products.htm#Honda
Re: emanage install *searched* (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi »</TD></TR><TR><TD CLASS="quote">Is this what you were given
http://www.autosportwiring.com/products.htm#Honda</TD></TR></TABLE>
wow, that is definately not what i got...all i got was a small diagram...thanks for the info.
No problem, but the problem now is that Greddy's directions suck in the first place and most of the time dont make any sence. Take you time and double check everything.
Enjoy
Enjoy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi »</TD></TR><TR><TD CLASS="quote">No problem, but the problem now is that Greddy's directions suck in the first place and most of the time dont make any sence. Take you time and double check everything.
Enjoy</TD></TR></TABLE>
ugh, thats not good to hear....the turbo install was terrible with those directions...so im hoping the emange isnt as bad....as long as i follow a long and use some common sense, should i be able to figure it out?
It helps to have some expierence in installing things like that, just make sure that you install the kit with the AC condenser out, it will make things a lot easier, and if you are using the 18g port the wastegate flapper before you install things, it will get rid of the boost spike that happens if you ever decide to run open downpipe. Oh and be careful with the studs provided in the kit, they kinda suck. If i was you i would ditch the whole greddy EMS in the first place. Just get a chipped ecu and be done with it, the e-manage doesnt have timing correction, so if you are running too much timing you will slowly eat away at you motor, go with Uberdata or Neptune and actually tune the car, you wll be much happier, i can tell you this with personal expierence.
Anything else i can tell you top to bottom on the greddy kits and any install info needed.
Also Greddys oil return lines suck, they tend to leak, so if you see any oil from anywhere look directly to them. Go to stealthmode and get their oil line kit.
thanks a lot for all the help...i already have pretty much everything installed. its a 19t kit...all i have left are all the pipes and the emanage...the emanage is whats stopping me from finishing...and yeah i would want to get a chipped ecu etc, but it would end up costing way too much, and taking way too long. i just need this thing running. ive been out a car for too long. i might eventually switch to something better, but at this point i just want my car back.
Mag00n
10
08-04-2006 10:12 AM
