EGT probes revisited
Okay ...this is a real stupid newbie..girlie question so forgive me...no flames please...I need to know:
I need to drill a hole in my ex. manifold; is it safe to do it without removing it from the block, or can I do it while its still attached? I figure the the metal shavings would be blown out through the exhaust, ..am I missing something?
[Modified by MiraiZ, 7:15 PM 2/28/2002]
Re: EGT probes revisited (DSF)
In any even, the shavings are headed out of the exahust anyways. My only concern would be the metal shavings damaging the turbine... possible?
Re: EGT probes revisited (MiraiZ)
imo why risk it? dont be lazy, your parts are too expensive to risk over a little saved time.
hell your turbo seals could be leaking ever so slightly and some of those shavings enter the oil, kiss your bearings goodbye.
[Modified by lucas569, 9:37 AM 2/28/2002]
Re: EGT probes revisited (lucas569)
put it in the downppipe.. and take it off the car to do it... not worth destroying a turbo or crackign a manifold for an EGT probe... if you screw up the manifold, thats a chunk of change compared to a downpipe...
Re: EGT probes revisited (GSRwBOOST)
i had it done in my manifold i made sure that there was nothing attachted to it. took the turbo off and unbolted it from my car and brought it to a friend who has some real sharp bits. i did it like that b\c i didnt want any shards getting into the head or getting into the turbo ( i also did the same when i had to get the other o2 sensor installed for my air fuel gauge, took the whole downpipe apart so that nothing can shoot up into the turbo. i have bad luck so it would have happend to me heh)
[Modified by TurboGsR.com, 1:23 PM 2/28/2002]
Re: EGT probes revisited (VTC_CiViC)
I think he means like this:
It works, and the numbers are accurate (it is before the turbo).
But having done both (downpipe flange before turbo AND on the #3 runner) I can tell you that the gauge responds MUCH MUCH faster tapped to the #3 runner on the turbo manifold. Worlds of differnce... From idle I can raise the RPM and just instantly watch the EGT increase.
Dustin
Dustin
Re: EGT probes revisited (dustin)
Pull the turbo, drip and tap into the manifold. Unless you are feeling brave and have extra cash sitting around for a new turbo.
Lessons can be learned through others mistakes, or they can be learned the hard way (no I didnt blow my turbo up like that! lol )
Re: EGT probes revisited (TurboMiata)
Since my turbo is used it came with two tapped EGT locations. I used the one on the rear since I didn't want to drill a hole and weld a bung into the #3 runner.
