EGT ON FULL RACE MANIFOLD
Old 12-19-2003, 09:44 PM
V-SPEC 1's Avatar
Default EGT ON FULL RACE MANIFOLD
Does anyone here have thier full race manifold drilled and tap for the egt? how far did you put the sensor on and what runner. I'm hesitate to drill and tap my mani, it's too purty to drill a hole into. . But I'm willing to do so in the name of reliability. Thanks
Old 12-19-2003, 09:55 PM
nojoke's Avatar
I believe you can send it to Full-Race and they will do it for you.
The optimal place to put it is on the number 3 cylinder runner.
Old 12-19-2003, 10:00 PM
PHiZ's Avatar
Default Re: (nojoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nojoke &raquo;</TD></TR><TR><TD CLASS="quote">
The optimal place to put it is on the number 3 cylinder runner.</TD></TR></TABLE>
-PHiZ
Old 12-19-2003, 10:46 PM
igotyofire's Avatar
Default Re: (PHiZ)
dont they usually go on the down pipe?
Old 12-19-2003, 10:48 PM
Kwuaymaikrup's Avatar
Default Re: (igotyofire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotyofire &raquo;</TD></TR><TR><TD CLASS="quote">dont they usually go on the down pipe?</TD></TR></TABLE>
You can but #3 usually runs a tad hotter than the rest so it is a good idea to keep an eye on this cylinder.
-Ryan
Old 12-20-2003, 01:40 AM
Dee
Dee's Avatar
Default Re: (Kwuaymaikrup)
Over here the turbine housing is the common spot for an EGT. My old turbo had 2 holes tapped in it.
Old 12-20-2003, 06:07 AM
V-SPEC 1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">
-Ryan</TD></TR></TABLE>
OK, on the pic above, do you prefer to place the sensor on top of #3? or to the bottom left. Thanks
Modified by boostedb20vtec at 10:39 AM 12/20/2003
Old 12-20-2003, 06:26 AM
New User
Boostfed's Avatar
I've got mine on my #4 cylinder, I did want it on the #3 though. I had a Computech EGT gauge on there temporarily that I borrowed from a Mustang guy, it is a handheld one and does record and playback etc. I just bought the Greddy EGT from Wiredspeedlab and will be installing that this coming week.
Old 12-20-2003, 07:00 AM
fullracegsr's Avatar
Default Re: (Boostfed)
i have mine #3 runner about an inch from the head... air temp readings will vary a couple hundred degrees from runner to downpipe...
Old 12-20-2003, 07:03 AM
buck02's Avatar
Default Re: EGT ON FULL RACE MANIFOLD (boostedb20vtec)
i have a full-race mani and ma ireally dont want to tap it it to fine will it be acurate for using in the turbine housing or the begining of the down pipe
Old 12-20-2003, 07:37 AM
Default Re: EGT ON FULL RACE MANIFOLD (h22civic2)
its ok to tap in dp i guess... autometer recommends it but i had it put into the 3 runner to get the most accurate readings ... i had someone who tested in before put one in the #3 runner and one in the downpipe at the same time and it varied a couple hundred degrees... runner is the best and most accurate in my opinion...
Old 12-20-2003, 10:27 AM
kpt4321's Avatar
The runner will also react faster, since putting it after the turbo basicially averages it over the 4 cylinders and over time.
On the other hand, keep in mind that runing an EGT before the turbo can kill your turbo if the end of the probe breaks off.
Old 12-20-2003, 10:47 AM
fulldragcrx's Avatar
the mounting instructions that came with mine say one inch fron the header to head-flange in any cylinder. But ill keep the cyl #3 info in mind when mounting mine...
Old 12-20-2003, 11:12 AM
Default Re: (boostedb20vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedb20vtec &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by boostedb20vtec at 10:39 AM 12/20/2003</TD></TR></TABLE>
Well the pic isn't working but I put mine on the bottom of the #3 on my Lovefab mani. Top or bottom will work equally well. Just find out what best suits your space requirements.
-Ryan
Old 12-20-2003, 01:24 PM
TurboJesse
Guest
Posts: n/a
#3rd runner if want the most accurate results, im guessing all of you who don't want to tap the manifold just bought it for looks
Old 12-20-2003, 04:53 PM
Default Re: (Mpir3)
to me it seems that if you install it into the downpipe by the time the guage reads the temp to warn you there is a problem your motor is probably overheated and about to go anyway... studies have found that the #3 cyclinder is often the cyclinder which goes first... like someone said in the downpipe your reading all four cyclinders instead of one and the air has to travel through the exhaust housing of the turbo and into the downpipe to have the reading....
Old 12-20-2003, 06:07 PM
V-SPEC 1's Avatar
Default Re: (fullracegsr)
hmm, so what is the best way to drill that thick *** SS manifold? I have the 1/8 npt tap and 11/32 drill bit. Do I need to start with small bit as a starter right? Thanks for all opinion.
Old 12-20-2003, 09:27 PM
LiLOtaku's Avatar
Just make sure you use plenty of "lubrication"(oil) when you drill and tap the manifold. I went straight for it, using the drill and just tapped it.
Have fun :D
Old 12-21-2003, 01:56 AM
Full-Race Javier's Avatar
we can tap the manifolds if you want, just let us know. as for the process, a center punch, center drill, and the required drill bit is a good way to drill a hole.....you might also want to use a drill press
Old 12-21-2003, 06:14 AM
buck02's Avatar
Default Re: (Full-Race Javier)
well yall all know how long the prob is on the autometer when you tap it and screw it on its not good for the probe to touch the other side of the pipe right it will get the temp of the pipe and not the gas please correct me if im wrong
Old 12-21-2003, 10:47 AM
Default Re: (h22civic2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22civic2 &raquo;</TD></TR><TR><TD CLASS="quote">well yall all know how long the prob is on the autometer when you tap it and screw it on its not good for the probe to touch the other side of the pipe right it will get the temp of the pipe and not the gas please correct me if im wrong </TD></TR></TABLE>
It is long but if you use the right adapter it works perfectly. Mine did atlest.
Old 12-21-2003, 11:43 AM
hybrid93SIvic's Avatar
mine is tapped into the #3 runner...works great
Old 12-21-2003, 12:18 PM
Dublocivic's Avatar
Default Placement
You want to have the EGT sensor mounted on the hottest (#3.) Drill the hole half of the width of the primary tube away from the head.
ie: On a 2 inch runner you would want to place it one inch down from the head on the third runner.
Old 12-21-2003, 12:53 PM
Flamenco-T's Avatar
Default Re: Placement (Dublocivic)
I welded my egt bung on the my manifold, the runner are so thick, I don't think I have any tap that will tap it as clean as I want. I had the runner drilled and the EGT bung welded on the underside of the # 3 runner
stan
Old 12-21-2003, 03:33 PM
buck02's Avatar
Default Re: Placement (Flamenco-T)
can someone post a pic of there install on there fullrace mani or just a equal length preferably the autometer probe
Quick Reply: EGT ON FULL RACE MANIFOLD
