EG Aftermarket Oil Pressure Gauge Issue
I have a APC Oil Pressure Gauge in my EG and its staying above 100 and not moving at all. I turn the car assc ignition and it moves above 100, i crank the car and the needle bobs down and back to above 100. Is my oil pressure sender unit bad?
Re: EG Aftermarket Oil Pressure Gauge Issue
Sounds like a bad sender. Mine is 75 or a little over right after startup with a 15-40 oil. After a couple of minutes of idling, you should see it start to go down to around 20-25 at fully warm. See if you can get a new sender and try that.
phateless
05-01-2006 07:01 PM
EJ1 wilcox
09-05-2004 03:41 PM
15psi of fun
07-23-2003 08:16 AM
100, 2010, accord, aftermarket, forums, gage, gauge, gauges, honda, hondaoilpressuregauge, installing, oil, pressure, problems, sensor
