The Effects of E85: Parts Test
Boost Works NY is doing some testing along with Tonio (on these boards). We want to solve all of the E85 rumors.
How will the fuel effect various car parts? What will it corrode? What wont it eat away at? We started the test on 04/25/2010 at around 6PM EST 04/26/2010: No changes. Marked fuel level to record evaporation. 04/27/2010: Slight fuel evaporation. No appearance changes to any parts. We have several parts submerged in E85 and we will be recording (and posting) the effects, if any. This is the list of the parts we have 1.5" Sch 10 Pipe 304L Stainless Steel Elbow 1.5" 316L Stainless Steel Tubing 3/8" Heater Hose Arias Forged Piston Steel Braided Fuel Hose Nylon Braided Fuel Hose Electrical Tape Various Anodized Fuel Fittings (used & new) 1/4" Nylon Tubing Brass NPT to Barb Fitting Injector O-Rings Stainless Steel Filler Rod Aluminum Filler Rod 12 Gauge Wire 18 Gauge Wire (some copper exposed) U.S. Quarter Mild Steel Washer NGK Iridium Spark Plug Hose Clamp -4 AN Steel Braided Hose Aeromotive Fuel Filter Scion tC OEM Fuel Rail (half) Scion tC OEM Fuel Pump http://i862.photobucket.com/albums/a...t_04252010.jpg |
Re: The Effects of E85: Parts Test
nicee. how long will these parts stay submerged?
very interesting
subscribed |
Subscribed :)
Originally Posted by Pumpking.
(Post 42287517)
No set time. Until we see results. Could be years
I'm interested to see the results as i'm daily driving my car on E85. I have yet to have any issues with it....**fingers crossed**
We ran a car on it last year for about 3 months.
Dual Walbros (one inline), stainless fuel line, aeromotive regulator, golden eagle rail. ALL of the parts were perfectly fine but the car began giving us a bad misfire under mid to heavy load. After tearing the engine down we found A LOT of carbon buildup on the exhaust valves. We believe this caused the misfires. |
in to see what happens.
I am interested also I have been driving for 2 years now on e85 in mine with no issues at all.
Originally Posted by b16racereg6
(Post 42291354)
I think the first thing that will fail is gonna be the cake pan that's holding everything. I'm starting a build thread soon. I'm going to be running on the same local E85 as above. We shall see what happens.
keep adding fuel.... it evaporates quickly....
the tape and anything plastic or rubber may die... but they would also **** up on 93 or c16 etc.... great thread!!!!!!! |
good stuff. in for results
We will see what happens! ps. Have faith in the cake pan tonio |
Good work guys
Might I suggest adding some sections of OEM Metal Fuel Line and maybe an OEM Fuel Filter to the mix... In to see what that Arias piston looks like my new motor has them but they are coated. When I tore my last motor down I did not find any "Carbon Deposits" but I did find a good bit of chalky white powder on my exhaust valve stems. |
Then pan is pretty full haha
Plus I dont think anyone would be using OEM fuel lines with E85 |
Originally Posted by boostworksny
(Post 42293605)
...i've been running E85 on the stock lines since June of last year (and that includes driving it all winter on ~E70) |
I definately know of a few running all stock stuff (lines, filter etc) and at one time I used my stock feed as my return so I did it for a while as well.
interestingg
In for results. How often are you going to check the parts to document any changes?
Will be checked daily.
Just checked. No changes on any parts.
you should put some injector seals in there cause since i been using e85 evrytime i drive it hard they leak the next day..
We have 2 injector o-rings in there.
