Edelbrock VictorX finally installed
as any one expericence a loss in power with this manifold? i did i have a b18b and i did notice i lost power, well i got it because im putting turbo so i have to wait until i get turbo to feel the power i guess.
1 Post
Re: Edelbrock VictorX finally installed (godrifttoday)
its not recommended for a stock NA motor, especially more if you built the block with low compression pistons. You wont gain anything. Its more for boost applications or high compression all motor.
Re: Edelbrock VictorX finally installed (drift2004)
what's with the bump? that guy already told you... i'm sticking to my stock gsr manifold, it will be good enough... i won't need an aftermarket manifold unless i'm making big power 300+ whp
Re: Edelbrock VictorX finally installed (SHystrdyGSRtdy)
how much power are you going to make with the turbo? you building the motor?
I doubt you'd see much gains unless you are running 400+whp with a turbo and launch at 6000+rpm at the track.
