E85 stations across the USA
I'm providing this link for those looking for E85 Stations near you. If you know of a station that is not on this list the link will allow you to submit the information.
http://www.e85refueling.com/ If you are curious about E85 we have threads available and this site helps. I also have a PDF file they sent me if anyone is interested in it. I can email it. Use E85, burns cleaner and it's basically a great substitute for race gas at the pump. Know the consistences in your area so you don't make the mistake in Using e70 when your tuned on E85. |
Re: E85 stations across the USA
Wrd, Thanx
sick
Burke in Chelsea MA listed as a dealer..........but they will not sell e85 without a car present
Tried buying some e85 with race gas jugs and they said no only if a car is present |
wow strict. HEB ftw
Originally Posted by teefunk01
(Post 37442015)
If they say its a legal issue with it not being a EPA-recognized flex-fuel car, you can always pull the "off-road only" baloney, which takes EPA mostly out of the picture. You could also tell them how your lawyer alerted you that it's susidized by your own tax dollars. |
as of january 1st, the new spec for denaturant blending is 2.0-2.2% natural gasoline, and allowable water content went from .8% max to 1.1% max per Karl Fischer titration.
Just FYI. |
(Post 37442015)
Tried buying some e85 with race gas jugs and they said no only if a car is present you should of told him the car is in the parking lot.. |
(Post 37442015)
Tried buying some e85 with race gas jugs and they said no only if a car is present To me its a crock of sh!t because you can go fill up a 10 gal can for a lawn mower... nobody seems to care about that. |
Originally Posted by 91civicDXdude
(Post 37506524)
Just FYI. break this down in lay-mans terms so people can understand and how it effects us |
Originally Posted by wilham320
(Post 37547432)
I had this issue with a station in NM. They said it was because they dont have a license for bulk selling/transportation... something about how the containers are not grounded or "certified", and only can transfer fuel into vehicle tanks.
Originally Posted by HybridcivicLS-T
(Post 37547605)
Karl Fischer titration is the method used to determine water percentage of a substance in low amounts. |
so for those that are tuned on E85 will we need a retune and when will this effect take place?
The user-level change is a slightly higher ethanol %, by about 2-3%, using a lower octane denaturing ingredient. I don't have a good calc with me atm, but I suspect the octane # should stay roughly the same but require 1-2% more volume to keep the same AFR's.
Cliffs - ~0.25 point AFR lean-out w/o changing tune, very slight milage decrease. |
(Post 37442015)
Tried buying some e85 with race gas jugs and they said no only if a car is present have you tried the one at logan yet? |
not a bad list at all. within a couple miles from me. but non in the city :(
thank's for posting |
sweet theres one 15 miles away from my house!
Virginia Beach FINALLY has a E85 station here on the military base (for public use)
I'm stoked, I don't have to drive to Richmond (1.5 hours away) |
Did you see that theres one located in the portsmouth naval shipyard too :-).
Thanks for the link...http://******************/images/de5...93cab9d72e.gif
Nice there is 1 5 miles from me
sorry if someone already asked this, but if im running standard pump gas what do i have to do, if anything, to run E85??? the closest station to me is 80 miles, which isnt worth the drive, however im sure there will be a station serving up a nice helping of this locally fairly soon. thanks for posting this
Weird, i thought everybody had e85? im in Minnesota and i see it all the time... i know of atleast 2 stations within 5 miles
Originally Posted by FearTheH
(Post 38147214)
