e or s housing on sc61 for a sr20det?
Ok the head will have cams, springs, intake, and a few other things in the future but what housing ona sc61 will be best, is the S housing an overkill? also can someone post a pic of the 2 side by side? is the E just a bit to small? thanks any help is apriciated
I am a bad person
Re: e or s housing on sc61 for a sr20det? (DLB1994)
I would go t04e . the t04s is not overkill it just doesnt show any huge gains. i made 559@22psi on a t04e housing.
Re: e or s housing on sc61 for a sr20det? (MotorMatrix.com)
I agree with mike. Supposedly the S housing flows 10% more, but the E is more efficient. I say supposedly cause thats what we are all told, and there isnt any proof as of yet----unless I missed something.
I like my E housing. Makes good power and spool up time is quick. It has a 2" outlet compared to the S' 2.5 (or 2.25 ??). Unless you have the ic piping and intercooler setup to flow more air, then i dont think its worth it. Also sometimes bigger isnt always better in terms of IC piping and intercooling, so take that into account as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 »</TD></TR><TR><TD CLASS="quote">
t3/t04e 57trim vs t3/t04s 60-1</TD></TR></TABLE>
So the only dfference on the E housing and S housing is that the E housing is polished all purty?
I live under a rock
Re: e or s housing on sc61 for a sr20det? (Boostfed)
that seems to be the consensus at the moment........ but i'd say the s-comp would flow more.......... but spooling higher than the E so it depends on what RPM range you'd be in.....for your setup
Re: e or s housing on sc61 for a sr20det? (spoolinlude)
As of now the head is stock, I will be getting 270 cams, RAS, and valve springs but even then i would not be pushing it over 7,500rpm. Now if it was ahonda i would take it to 8,500rpm all day long. thanks for the advise so far. Also what diffrence does the exhaust size make and how should i select? 48. 63. 81. 58. 68?
Where will this size play into effect? thanks again
i have never seen any evidence that a larger a/r on the compressor side hurts anything, in fact i have seen research that concludes a larger compressor can only help. The downside to a big compressor housing is simply the amount of space it takes up...
Re: e or s housing on sc61 for a sr20det? (FFgeoff)
also want anyone throw up a pic of a sc61 next to a drag3 style t3/4 so i can get a size? thanks
Re: e or s housing on sc61 for a sr20det? (turboex)
RAS. I don't think everyone knows what that is
Rocker Arm Stoppers
SR20's have a bit of problem with the rockers flyig around at high revs, so you stop them from doing that
Rocker Arm Stoppers
Re: e or s housing on sc61 for a sr20det? (javierb14)
Yeah some times you can rev the hell out of them, and other times they will break, its just insurance
I live under a rock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboex »</TD></TR><TR><TD CLASS="quote">other times they will break, </TD></TR></TABLE>
i'd like to see that happen.... sounds cool
bump.... i am about to get another sc61 and i would liek to know if it is worth paying extra to get the S housiing.... any new information since this thead was made?
Re: e or s housing on sc61 for a sr20det? (NextelBuddy)
Probably not new info....My own opinion is it depends on what you are using the car for.....If mainly a street car then i would stay E cover, But then again the sc 61 could acually be too much for a street car with the right setup.
If it is used for racing then I would go S cover.....There is no negative side to the bigger cover other than maybe spool, which doesn't mean sh*t when racing.
Those are just my opinions.....Also maybe look into a turbo that a company can keep on stock? But here is a pic for you, the sc61 T04S cover .70 A/R next to a stock 14B turbo from a talon......
Re: e or s housing on sc61 for a sr20det? (80884)
what are you using for a maf?or are you using something with a map sensor?if your maf is smaller than the 4" inlet of the s,you might as well go with the e.i would use the .63 a/r exhaust housing.you should still have pretty good spool with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 80884 »</TD></TR><TR><TD CLASS="quote">Probably not new info....My own opinion is it depends on what you are using the car for.....If mainly a street car then i would stay E cover, But then again the sc 61 could acually be too much for a street car with the right setup.
here you go
so does anyone know how much difference the 150 dollar S housing is? is it worth it?
here you go
Full-Race.com
12-23-2010 04:20 PM
