Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   e-manage interaction light suppose to constantly blink? (https://honda-tech.com/forums/forced-induction-16/e-manage-interaction-light-suppose-constantly-blink-1184461/)
mike93eh Mar 19, 2005 09:29 AM
when i put the emanage in check mode by just turning the car on, the lights come on but none of them blink. but with my car running, the interactive light (laptop connected) not the active light but the interactive light constantly blinks. is it suppose to do this? i thought this light comes on when a laptop is connected.
mike93eh Mar 19, 2005 12:50 PM
oh im the only person on here with e-manage...
mike93eh Mar 19, 2005 02:21 PM
its real simple. if you are running e-manage, tell me if your interactive light constantly blinks when running.
Tchleung Mar 19, 2005 02:23 PM
my friend doesn't in his Ralliart... Whenever it flashed or anyhting. there was generlaly something wrong
mike93eh Mar 19, 2005 02:43 PM
Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">Whenever it flashed or anyhting. there was generlaly something wrong</TD></TR></TABLE>
interactive or active led?
Tchleung Mar 19, 2005 02:46 PM
sry I don't really know Emanage. waht'st eh difference? I was referring to the lights on the sdie of teh actual blue emanage box. like 3 lights I think on the side
mike93eh Mar 19, 2005 03:04 PM
2 lights on the side.
1st light - interactive - supposedly lights up when you hook the laptop to it.
2nd light - active light, it can flash to give you the error codes and can flash different colors telling you something i forget.
Tchleung Mar 19, 2005 03:11 PM
Oh oaky. in taht case the interactive light always stayed solid. laptop hooked up or not.
mike93eh Mar 19, 2005 03:17 PM
Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">Oh oaky. in taht case the interactive light always stayed solid. laptop hooked up or not.</TD></TR></TABLE>
always stayed solid sounds as bad as mine constantly blinking...
we need some e-manage gurus
Tchleung Mar 19, 2005 03:24 PM
haha yea. seems like not many ppl use emanage comapred to other managments..
Goodluck tho man
mike93eh Mar 20, 2005 04:38 PM
anymore insight on this??
mike93eh Mar 21, 2005 01:55 PM
bump
tepid1 Mar 21, 2005 02:57 PM
Re: (mike93eh)
find the h-t member "The Shodan". He will know for sure. I promise.
NinjaTurtles Mar 21, 2005 03:21 PM
Re: e-manage interaction light suppose to constantly blink? (mike93eh)
It constantly blinks while the car should be running
mike93eh Mar 21, 2005 04:28 PM
Re: e-manage interaction light suppose to constantly blink? (NinjaTurtles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NinjaTurtles &raquo;</TD></TR><TR><TD CLASS="quote">It constantly blinks while the car should be running</TD></TR></TABLE>
but why would they make it so it constantly blinks doesnt make sense. its annoying me i guess i better put some tape over it hah.
mike93eh Mar 21, 2005 04:31 PM
Re: (tepid1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">find the h-t member "The Shodan". He will know for sure. I promise.</TD></TR></TABLE>
is he a e-manage master? heh ill pm him thanks..
JustinL Mar 21, 2005 04:44 PM
Re: (mike93eh)
mine kinda flashes like a cable modem in use. really fast jittery flashes not consistent with any pattern. i too was wondering what that was
mike93eh Mar 21, 2005 05:48 PM
Re: (pyro_assassin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyro_assassin &raquo;</TD></TR><TR><TD CLASS="quote">mine kinda flashes like a cable modem in use. really fast jittery flashes not consistent with any pattern. i too was wondering what that was</TD></TR></TABLE>
well hmmm, mine is consistent.
flash..flash..flash..flash..flash..
' Mar 21, 2005 05:58 PM
I have emanage. And YES the "interaction" light does BLINK in a steady pulse. This is because i was told there is no connection to comuter, hence the USB port. Not 100% sure.
But the main thing is the active light, the GREEN light. When you give it gas, the Active LED should TURN green and when you let off gas it will go to orange. If the active light is doing what i am saying, then it is working fine.
mike93eh Mar 21, 2005 06:44 PM
Re: (l337hxr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by l337hxr &raquo;</TD></TR><TR><TD CLASS="quote">I have emanage. And YES the "interaction" light does BLINK in a steady pulse. This is because i was told there is no connection to comuter, hence the USB port. Not 100% sure.
But the main thing is the active light, the GREEN light. When you give it gas, the Active LED should TURN green and when you let off gas it will go to orange. If the active light is doing what i am saying, then it is working fine. </TD></TR></TABLE>
alright i guess everything is okay then. thanks
i believe if youre below 1000rpms then its orange.
Hyaboosta Mar 22, 2005 07:30 AM
Re: (mike93eh)
yeah my emenage interaction light blinks constant. When the active light starts to go red,yellow,green then you FvCKED.
