Dynoed my GSR
Old 11-24-2001, 05:51 PM
LEON's Avatar
Default Dynoed my GSR
I dynoed my 99' GSR with the Drag Gen III kit today (5.8psi). I pulled 270hp and 180ft-lbs of torque. I'm very excited about the hp numbers, but a little disappointed about the torque numbers. What are the rest of you running as far as torque numbers?
Old 11-24-2001, 05:57 PM
Smarter than you
DIRep972's Avatar
Default Re: Dynoed my GSR (LEON)
no way dude, thats sick horsepower, especially only 5.8psi.. what exhuast set up u have and what other mods.. torque seem good too for that low of boost..
Old 11-24-2001, 06:01 PM
LEON's Avatar
Default Re: Dynoed my GSR (DIRep972)
Thanks!
I have a Thermal Exhaust with a 3" cat conv.
No boost controller... just the Tial wastegate with .4 spring ~ 5.8psi
Stock engine and clutch.
Old 11-24-2001, 08:23 PM
csufweed's Avatar
thats what you get with a good exhaust... very nice man. the 3" cat put you above the rest.
Old 11-25-2001, 06:50 AM
LEON's Avatar
Default Re: Dynoed my GSR (csufweed)
Can anyone host my dyno plot? I would like to get some opinions on the A/F ratios.
Old 11-25-2001, 07:25 AM
BoM
BoM's Avatar
man!
i bet you can easily get into the 300's with 8-10psi
what power...
[Modified by BoM, 11:25 AM 11/25/2001]
Old 11-25-2001, 08:48 AM
BMW Güdentyte
BLKMamba's Avatar
e-mail it to me. I'll upload it into my isp.
Old 11-25-2001, 09:03 AM
New User
smoothludey2's Avatar
Default Re: Dynoed my GSR (DB8GSR)
leon,
list your setup....i'm still in disbelief over the 270whp with only 5.8pounds of boost...especially since the drag kits don't post that much power with only 6 pounds of boost.
Old 11-25-2001, 11:38 AM
What is this crap?
falcongsr's Avatar
Default Re: Dynoed my GSR (rawdigga)
lean is mean? (at 4000 rpm)
Old 11-25-2001, 01:02 PM
98hx99b18c's Avatar
Default Re: Dynoed my GSR (falconGSR)
List your mods, also whats your vtec x-over at? Also how do your plugs look? Yes lean is mean!!!
Old 11-25-2001, 01:04 PM
dustin's Avatar
Default Re: Dynoed my GSR (98hx99b18c)
Sorta running lean there.
Old 11-25-2001, 01:43 PM
TurboR1391's Avatar
Default Re: Dynoed my GSR (dustin)
What is considered an ideal air/fuel ratio on the dyno plot?
Old 11-25-2001, 01:44 PM
98hx99b18c's Avatar
Default Re: Dynoed my GSR (Vonte')
Around 12.0 - 12.5
Old 11-25-2001, 02:21 PM
Rob03Pro5's Avatar
He's running kinda lean.. around 13:1.. which is why he's gettin such high HP. My friend got the same exact numbers on the same psi.. 5.8 with the TiAL. Same, just DRAG III and a 3" exhaust.
Old 11-25-2001, 02:25 PM
LEON's Avatar
FalconGSR - thanks for posting the dyno for me.
I have a stock GSR engine with the basic Drag Gen III kit with boost regulated by the Tial wastegate (.4 bar spring). 3" Thermal Exhaust with 3" cat. conv. I have not changed my stock VTEC crossover point.
I feel like I'm OK with the A/F above 5k rpms at 13-12.5, but I am a little nervous before that point. Are the A/F ratios dangerously lean? Any suggestions? My plugs looked fine the last time I looked at them (last oil change ~3k miles ago). I'll check them again next weekend when I change my oil again.
Old 11-25-2001, 02:35 PM
New User
FAST94GSR's Avatar
in the lower rpms yes you are dangerously lean. when cruising at lower rpms your egt temps will go sky high. richen them up.
Old 11-25-2001, 02:40 PM
LEON's Avatar
Default Re: Dynoed my GSR (FAST94GSR)
My EGT never goes above 800 C on a full WOT run (most of the time its 750 C) , and that 750-800 C is only up near readline. Cruising in lower rpms I'm around 500-600 C, and at highway speeds 70-80mph I'm between 600-700 C.
bb6guy
06-10-2011 01:44 PM
artin01
04-27-2010 09:48 PM
flangemastermike
01-20-2008 03:57 AM
95GSRT
04-22-2005 11:21 AM
Andrew 825SM
11-04-2002 09:50 PM
Quick Reply: Dynoed my GSR
