Dynoed my Car today...........
Well Here is my setup first
B18B
T3/T04E .63 ar/ 54 trim compressor
Zdyne Gold SECU 450 CC injectors
Drag FMIC
2.5 inch exhaust + dp No cat
open loop tial wastegate
best run at 8 psi was 189 HP/155 ft/lbs tq
I was hoping for more power but A/F was aready really lean if not too lean (13:1-14:1)
Don't know why I am not making anymore power then that but I think I would like to build the engine so I can run 15 psi I think then I would be getting better use out of the turbo
Also the head needs to be opend up to make more power. I a pic of the dyno plot but I don't know how to post it.
B18B
Drag FMIC
Re: Dynoed my Car today........... (vtecsiqt)
How? What kinda A/F ratio's are you running to run that much boost? Any thing done to strengthen the block?
What A/F should I see? 11:1 or 12:1?
Also right now I can't run any higher then 8-10 psi because I still have the stock map sensor. Once I get a 3 bar I can try running 12-15 psi.
Re: Dynoed my Car today........... (89civic1.8T)
I think a safe yet powerful A/F ratio is 12.5:1. It will take some tuning to get there but I think that is about where you should shoot for.
New User
Fulll boost it around 3000 rpms but the power takes abit to kick in. The rev limit is stock
Re: Dynoed my Car today........... (vudoo666)
you sould be aleast in the low 200 range with 8lbs and that setup. somthing is terribly wrong. **** my Sohc ghetto setup makes 186whp at 9lbs
Re: Dynoed my Car today........... (intekragsr)
It was a Mustang dyno.
And I get boost so early is because My turbine is a standered or a stage II wheel. Not a stage III like the rest of you luckey ones.
Re: Dynoed my Car today........... (Etylorcen)
I have a picture I took of the dyno plot. It's a large file but If someone could host it for me I could post it. Ecomplanet isn't working for me to upload it.
Smarter than you
1) that is a mustang dyno, its gonna be low
2) u r way too lean. try to get it around 12:1. boost loves fuel.
3)that stage 2 wheel is really holding u back.
Joe-G
06-07-2010 11:32 PM
not2slo128
07-25-2006 03:24 PM
s1ngle
05-03-2005 07:14 PM
