Dyno results back...seems a too low
I just got off the phone with Kitty at Autolink motorworks, she said my car after tuning was a 175 whp. Does that seem low for this setup:
Stock b16a2
Drag Gen III kit
V-AFC
DSM 450cc
Apex'i WS cat-back - 2.25 inch piping
The ONLY thing I could think of is the 2.25 inch piping is keeping the turbo from spooling fast, so I am not reaching 7 psi by redline, because my autometer boost gauge says 5, but its an autometer, so i don know.
Would 2.25 inch piping hold back my HP numbers TAHT much? I thought drag kits on a b16a2 would make at LEAST, 200 whp. Thanks
Stock b16a2
Drag Gen III kit
V-AFC
DSM 450cc
Re: Dyno results back...seems a too low (Hoodwinked)
bump for needed opinions...
is it true I could gain another 30 whp just by adding a 3" cat-back?
Re: Dyno results back...seems a too low (DLB1994)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 »</TD></TR><TR><TD CLASS="quote">you got the afc hack ? and what kinda dyno was this on?</TD></TR></TABLE>
yes i have the hack, its on a dynojet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoodwinked »</TD></TR><TR><TD CLASS="quote">bump for needed opinions...
is it true I could gain another 30 whp just by adding a 3" cat-back?</TD></TR></TABLE>
Don't even worry about it dude...when I first had my car dynoed, I had a bone stock b18c1 with a revhard stage 2 kit. I too had a 2.25 inch exhaust and at 7 psi, I only managed 170 whp . After I got a 3 inch exhaust, injectors and the hondata tuned, I made 232 whp with 7 psi. Just get a 3 inch exhaust and the numbers will go up good luck
My old drag 3 kit b16a2 on a mustang dyno with Hondata, Tanabe RM(maybe at most 2.5") made like 190whp at 7psi. I did have no cat however.
I didn't have a problem hitting full boost by around 4k rpms though on t3/to4b.
Your exhaust will still let you reach 7psi or more so that can't be your problem. smaller pipping just make spool time longer.
Re: Dyno results back...seems a too low (Mr.DC2TurBo)
smaller tubing makes the spool time longer? you mean the time for it to spool up? i thought smaller tubing made the turbo spool up faster?
Re: Dyno results back...seems a too low (Del_Slowest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slowest »</TD></TR><TR><TD CLASS="quote">smaller tubing makes the spool time longer? you mean the time for it to spool up? i thought smaller tubing made the turbo spool up faster?</TD></TR></TABLE>
i said PIPING.. exhaust.
Re: Dyno results back...seems a too low (J.R.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.R. »</TD></TR><TR><TD CLASS="quote">
Don't even worry about it dude...when I first had my car dynoed, I had a bone stock b18c1 with a revhard stage 2 kit. I too had a 2.25 inch exhaust and at 7 psi, I only managed 170 whp . After I got a 3 inch exhaust, injectors and the hondata tuned, I made 232 whp with 7 psi. Just get a 3 inch exhaust and the numbers will go up good luck</TD></TR></TABLE>
So 175 whp on my setup would be reasonable then...since im running a 2.25 inch exhaust and stock cat? What other things could cause it to make less power? BOV leak? intercooler piping leak? Also, my gauge says im only boosting 5 psi, but my tial wastegate is set to 7 psi. is it possible to lose 1-2 psi through my intercooler?
calvinPGMFI
02-12-2006 02:43 PM
WAFFLES
06-30-2003 07:33 PM
