Ductile Iron Sleeves for $40 each??
http://www.jgenginedynamics.com/specials
Ductile iron sleeves for D series blocks only. Can accommodate pistons from 75-79mm $40.00 each
So.. someone enlighten me.. why pay $800 to get a sleeved block when you can pay $160+labor?
Re: Ductile Iron Sleeves for $40 each?? (sushibug)
Usually takes a few hours if not more to do internal engine work. Shops charge usually by the hour. $65 - $85 an hour or something like that, after a few hours it starts getting expensive... Unless they have set rates for doing stuff. $300 labor for x work, $550 labor for y work etc...
and seeing the link those sleeves are at, i'm sure as HELL not gonna trust any type of quality to come from there after recent reports.
Re: Ductile Iron Sleeves for $40 each?? (zoomintegra)
Those sleeves dont have a seat which holds them up in the block like darton or GE. I saw a block with those sleeves at a shop and the deck was not true. It was a complete waste of money.
Re: Ductile Iron Sleeves for $40 each?? (SO3Burner)
Long deal on a sleeve install would be $450. Seat for the sleeves is machined into the motor, not on the sleeve.
Re: Ductile Iron Sleeves for $40 each?? (earl)
Edit: i meant JG not JE
[Modified by SO3Burner, 8:23 PM 11/20/2002]
