dual exhaust setup... haters?
Old 10-08-2010, 07:59 PM
DelSolMarine's Avatar
Default dual exhaust setup... haters?
So many of you saw my thread where my car was making less power on my setup than I originally anticipated. https://honda-tech.com/forums/showth...ghlight=545whp
Well it looks like the problem was the muffler that I originally had located around my shiftlinkage...magnaflow 5inch round barrel... well at 13psi my car reading 11.7-11.9 af and after cutting off the muffler and welding in a straight 3 inch pipe the cars a/f's at 13psi started reading 13.9-14.1 but it sounded like an indy car which i refuse... well i like to do things differently so i decided on this setup... the afs are reading 13.9- 14.1 just like before... obvious fuel adjustments are needed but my exhaust flow is up to par as well as it sounds like a freakin evo... it is REALLY deep... i will try to get a video... im sure there will be plenty of haters... but i am extremely happy with my new exhaust setup!
Old 10-08-2010, 08:24 PM
2k.civic.si's Avatar
Default Re: dual exhaust setup... haters?
hmmmm....
would i be crazy for saying i kinda like it?
Old 10-08-2010, 08:29 PM
Spawne32's Avatar
typically they dont ever sound that good, and add excess and unnecessary weight, but im interested to see how it comes out.
Old 10-08-2010, 08:37 PM
i forgot to add a special thanks to ramey built for supplying me with the stainless 409 uj bends and the v band kit for a killer price.
exhaust fab work was actually done by a local welder jamie taylor in his bat cave garage... thanks!
Old 10-09-2010, 02:19 AM
K7-1Ktrevor's Avatar
looks nice to me, its refreshing to see something a little different.
Old 10-09-2010, 02:13 PM
jetspeedz's Avatar
if you have before and after videos of how it sounds it would be great to hear.
Old 10-09-2010, 04:00 PM
NonovUrbizniz's Avatar
It looks good and I'm sure it makes for a nice exhaust note... but FYI it's REALLY bad to have the exhaust exit under the car... you seriously run the risk of getting carbon monoxide poisoning and dying...
It's sometimes totally impossible to detect it until it's too late... and the damage is cumulative so you can get exposed slightly for a week or two then die from the built up effects...
I've thought about doing this a thousand time but won't look into it till I get my car up and running... If it's too loud how it is now I'll look into it. It's obviously just silly if you're not running a bunch of boost.
Old 10-09-2010, 06:01 PM
PaddingtonBear's Avatar
You get that from carbon monoxide and a lack of oxygen. Unless he has his windows up and a hole cut in the floor pan, he'll be fine. lol
Old 10-09-2010, 06:09 PM
what? that makes no sense... the exhaust is exitting out the rear of the car
Old 10-09-2010, 06:33 PM
some will still draw into the car. people run open down pipe cars all the time. you just have to deal with the smell and headaches some time.
Old 10-09-2010, 09:55 PM
H.A.R.T B18C1EG6's Avatar
lol agreed
Anyway, I'm not a huge fan of duals on a car that doesn't come with it stock but that's my opinion. I guess I need more pics.
Old 10-09-2010, 11:06 PM
Master Detailer
98civdx's Avatar
Persoanly i dont care for dual exhuast on civic's, but it's your car, if you like it then go for it.
I'd be interested to see how it sounds.
Old 10-10-2010, 10:53 AM
welfarepc's Avatar
would be cool to see them turned out and exit before the rear wheels.
Old 10-10-2010, 11:05 AM
levee000's Avatar
Looks good man an its all up to you. Your car your choices. I think it actually looks good not like anyone will see it.
Old 10-10-2010, 12:14 PM
krazyhmongboi's Avatar
ever thought about doing an e-cut instead?
Old 10-10-2010, 01:28 PM
HiProfile's Avatar
I like how it's not a "ricer" dual, where you really don't see it. Its heavier than a single pipe, but you can't argue it flows worse. I've only heard of people having issues with the louvered straight-through resonators. Magnaflo only uses perferated tubes that I know of.
Personally I'd have gone with an e-cutout. I put one on my DD, which is 3" from the turbo to the gas tank w/18" louvered 5" resonator, which necks down to the stock exhaust pipe & muffler after that. The cutout faces the gas tank (heat shield still in place), and I've ran that setup for about 10k miles so far. Mine is a custom unit I made, which is more user friendly. It can open up itself at 60% throttle and above.
Old 10-11-2010, 12:11 PM
extralargenog's Avatar
Ricer.
I have made a point to skip your threads until now...
I am back on the wagon. Your logic/taste is just.... meh, forget it. Maybe you need BIGGER cams to flow more exhaust through your mufflers, maybe that will fix your boost too...
DER
Old 10-11-2010, 08:08 PM
Originally Posted by extralargenog
Ricer.
DER
lol... skunk2 pro1s are enough cam
Old 10-11-2010, 08:12 PM
boostedef8!'s Avatar
thats a tight squeeze behind ur LCA's
Old 10-11-2010, 09:05 PM
onefstek's Avatar
I allways wanted to do a dual exhaust with stock mufflers on a built n/a street set up. Maybe some day ill get around to it. Nice work btw.
Old 10-11-2010, 11:08 PM
^iv never once thought of that lol.
Old 10-12-2010, 06:36 AM
Moderator in Chief
Muckman's Avatar
I love to see something different that's done well.
Old 10-12-2010, 09:12 AM
93egSLEEPER's Avatar
I WANNA HEAR IT!!! please
Old 10-14-2010, 03:56 PM
spawn_616's Avatar
ya in for a vid,high quality one
Old 10-15-2010, 05:09 AM
Im not to sure about "high quality" but i should have one tomorrow.
The Del Sol will be on the dyno tomorrow morning in hopes of 700whp on C16!
Quick Reply: dual exhaust setup... haters?
