dsm blue top injectors
well finally got a few lil problems fixed with my car, i got some dsm blue top injectors and got the clips for them also to put in my ek hatch, i got b seriers swap with turbo running off just chipped ecu, and fmu, if put these in my car and wire up the resistor box, how will the car run, i heard it just floods it and will be hard to start and run well cause it'll run to rich without gettin hondata, or the ecu rechipped, has anyone did this on a stock set up, thanks
Re: dsm blue top injectors (honhatchisbak)
Im running blue tops with Uberdata right now. Car runs like stock.
Blue tops are great if you get them dialed in. They're not hard to work with and run really well. Your car will not flood if you have something to control the amount of fuel going in.... If you have a chipped ecu, you wont need an fmu.
twistedimage
03-28-2008 07:53 AM
