Driving w/ untuned HONDATA
is it safe to drive with an untuned hondata system on a boosted GSR?
i need to know because im not sure that the tuner can install it. im in tampa and theyre in orlando - so its not a short drive
thanks
thanks
Re: Driving w/ untuned HONDATA (Integra21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 »</TD></TR><TR><TD CLASS="quote">is it safe to drive with an untuned hondata system on a boosted GSR?
thanks</TD></TR></TABLE>
what do you need to install. if your driving around on a honda system then it must already be installed correct ?
but if you do have your hondata installed, and are running off a basemap. i would for sure not drive it for long. Keep it out of boost, and get to the dyno.
platinum.
platinum.
Re: Driving w/ untuned HONDATA (platinum00)
i have the greddy fmu right now but what im asking is if i get the hondata installed will it be okay to drive roughly an hour to get it tuned?
Re: Driving w/ untuned HONDATA (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">i would just take off one of the charge pipes... no tune=no boost</TD></TR></TABLE>
taking off one of the charge pipes could cause over spooling of the turbo. be careful.
just take it easy on her, and you should be fine.
platinum.
platinum.
that wouldn't be such a good idea because you can overspool the turbo like platinum said. Honestly boosting a little on the basemaps isn't gonna be all that bad. I've seen plenty of people running for over a year with a basemap and beating on their cars everyday.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 »</TD></TR><TR><TD CLASS="quote">would i be better off turning the boost way down? im at 7 psi now - what should i go down to?</TD></TR></TABLE>
uhhhh...you can't turn boost down past the spring!
Like everyone said, you will be just fine. Just do not give the car more then 50% throttle and don't rev past 4k rpm and you can go like that for days. Get the car tunned ASAP though because the bug to hit the throttle will come and bite...HARD.
Re: (respectblades)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by respectblades »</TD></TR><TR><TD CLASS="quote">ya man i know people stock injectors on boost for a year and ripping on it daily</TD></TR></TABLE>
FMU...that's why!
don't rip on it or touch boost until tunned...please, don't waste your investment
FMU...that's why!
would a tuner install the hondata normally?
im new to FI, is the Greddy 18G kit spring at 7psi the lowest?
I've been on a basemap for almost 2 years, LMAO. I guess the one I have is ok otherwise my engine would be dead, right? LOL Anyway, I am scheduled to get tuned in two weeks.
Re: Driving w/ untuned HONDATA (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">
You can take the spring out of the wastegate...
Re: Driving w/ untuned HONDATA (Sam1am26)
Depending on where you bought it from you should be safe to drive on your basemap. All the ones i do are usually good enough to where the customer can drive on the car long distances but just not beating the **** out the car.
Ricky
Ricky
Re: Driving w/ untuned HONDATA (WIRED RICKY)
jesus what a bunch of stupid posts, bad information here.
I had the same situation as you except I had to drive from Orlando to Tampa to get mine tuned.
As long as you have a basemap and you do not go into boost, you'll be fine. I drove for like a month on the basemap before I had the $$ to get my car tuned.
DO NOT take off charge pipes or anything, just take wastegate spring out.
Ask sam1am26 above, he's my boy.
Re: Driving w/ untuned HONDATA (mike1114)
hmm... a guy at inline pro told me to take a charge pipe off. That would assure you dont see boost, and if you take it easy and stay under 3-4k, there isnt really a chance of 'overspinnig' the turbo.
you guys act like basemaps are extremely dangerious. You will have no problem dipping into a little bit of boost while you are on the basemap as long as whoever made the basemap knew what they were doing. Boosting like 5 lbs. on a properly made basemap isn't gonna hurt **** imo.
Re: Driving w/ untuned HONDATA (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">you guys act like basemaps are extremely dangerious. You will have no problem dipping into a little bit of boost while you are on the basemap as long as whoever made the basemap knew what they were doing. Boosting like 5 lbs. on a properly made basemap isn't gonna hurt **** imo. </TD></TR></TABLE>
I have not had any major problems with it, save for fouled plugs from running rich.
Re: Driving w/ untuned HONDATA (TurboSedan)
yea I drove on one for a long time and when i finally checked it with a wideband it was super rich. Actually it was a tuned map, but not for my setup.
Perhaps a boosted B16, for example. I have never had any noticable detonation. Recent compression tests are excellent at 184-180-186-185.
Rain_man
08-05-2004 10:00 AM
