Is the drain pan the ONLY drainage point for a turbo outlet?
I would rather buy brass fittings or something than take my pan off and weld a fitting into it. Thanks for all your input. Also, if I do have to tap my pan, where on it should I? Thanks
Re: Is the drain pan the ONLY drainage point for a turbo outlet? (WannabeTurbo)
You are going to need to return it to a point so that is can refiltered before entering the engine. After all the research and cost, it is better to just get the pan welded.
Here are links for the location
https://honda-tech.com/zerothread?id=262443
https://honda-tech.com/zerothread?id=234043
hope this helps
-deepsi
hope this helps
-deepsi
