drag turbo kit questions
I have a 1990 hatch with a b18c swap. I am planning on boosting it, and i have pretty much decided on the drag turbo kit. The kit comes stock set at 7psi and that is what i plan on running it at. I am fairly new to turbos and i have few questions before i drop the money on this kit.
Which turbo would you suggest for a stock b18c?
T4e 60 Trim
T4e 57 Trim
To4b Super V Trim
To4b Super S Trim
What else will i need that does not come with the kit?
Will my stock injectors be fine at 7psi or will i need larger injectors?
Will i need a halfcore radiator?
The car is currently tuned using chrome. Will i need any other fuel management besides getting my ecu re-tuned for boost?
Will i have to shave the block to make the manifold fit?
Any input is welcome. If you would recomend a different kit in the same price range please tell me, and tell me why you would go with the kit you recomend over the drag kit. Thanks in advance.
T4e 60 Trim
T4e 57 Trim
To4b Super V Trim
To4b Super S Trim
Re: drag turbo kit questions (dontgodumb)
I have part of a drag kit on mine. You won't need to shave the block if you go with a T3 turbo. Not sure about the T4, the compressor side looked kinda big and it would be a tight fit, so I didn't get it. I didn't want to shave anything.
Don't need a halfcore radiator. I'm still running stock.
Running @7psi on stock injectors, but if you already have a chipped ecu I'd get 310's or 440's. I want to say the stock fuel pump gets overworked past about 5psi, but I'm not sure what the exact number is. I'd upgrade, probably to a Walbro 190lph or something similar, depending on how far you want to go with this project. I'm running the 255 right now and it's overkill for my setup.
