drag manifold w/ 35mm tial wastegate????
Old 12-11-2004, 01:08 PM
b00sted4dr's Avatar
Default drag manifold w/ 35mm tial wastegate????
Ok, has anyone had issues with boost creep using a drag manifold and a 35mm tial wastegate? It will be with a .5 bar spring on a T3/To4b.
I know there posts before, but none that specified what size valve.
TIA
Old 12-11-2004, 02:15 PM
Chrome Pipes's Avatar
Default Re: drag manifold w/ 35mm tial wastegate???? (That4drGSR)
T3/TO4E - when I drop gears and punch it, it spikes up to +5 psi whatever I have the boost set at, then comes back down. This only started happening once I started running around 15 psi. Its a well know fact that the wastegate placement on these manifolds is crap. If you are running below 10 psi I dont think there will be a big problem.
Old 12-11-2004, 02:32 PM
b00sted4dr's Avatar
Default Re: drag manifold w/ 35mm tial wastegate???? (Chrome Pipes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chrome Pipes &raquo;</TD></TR><TR><TD CLASS="quote">T3/TO4E - when I drop gears and punch it, it spikes up to +5 psi whatever I have the boost set at, then comes back down. This only started happening once I started running around 15 psi. Its a well know fact that the wastegate placement on these manifolds is crap. If you are running below 10 psi I dont think there will be a big problem.</TD></TR></TABLE>
Oh ok. So how much were you boosting before it started spiking? Were you using the 35mm tial?
Thanks for your reply
Old 12-11-2004, 02:43 PM
I was boosting 10 psi with no problems. When I started to go over 12, it started to spike. Keep in mind that the Drag manifold was probably designed for lower boost applications. When I was at InlinePro getting the car dyno'ed they told me that they always saw this happen with Drag manifolds at higher boost levels. They were probably trying to sell me an InlinePro manifold though!
Oh yeah forgot I'm using the Tial 35mm..
Old 12-11-2004, 03:02 PM
Rory Breaker's Avatar
Drag manifold, 2.5" downpipe and testpipe, 2.36" exhaust, 35mm Tial, 7PSI, ZERO creep
Drag manifold, 2.5" downpipe, 3" exhaust, 35mm Tial, 7PSI, Creep.
All in the piping for me and many others. When large piping frees up exhaust flow, it blows right by the wastegate due to its inefficient location.
Old 12-11-2004, 03:26 PM
b00sted4dr's Avatar
Default Re: drag manifold w/ 35mm tial wastegate???? (newgsrdriver)
Great info guys.
Old 12-15-2004, 11:13 PM
Trac226's Avatar
I'm curious if anyone used an ebc to control the creep. Only one way to find out.
Old 12-16-2004, 03:23 AM
markvqwerty's Avatar
Default Re: drag manifold w/ 35mm tial wastegate???? (Trac226)
i always thought that boost creep was likely to happen @low boost and not @ high boost!
your wastegate is working harder @ low boost! i was thinking of buying the drag mani to cause i think it outflows the inline pro or maxworz mani. ill gues ill buy a 38mm tial to go with it and ill be driving without a exhaust.
Old 12-16-2004, 05:14 AM
b00sted4dr's Avatar
Default Re: drag manifold w/ 35mm tial wastegate???? (markvqwerty)
Just an update.
I installed the drag manifold and i am running a 38mm tial wastegate with a .6bar spring with 2.5 OPEN downpipe. No boost creep whatsoever!!! I am very happy i get no spike It holds boost all the way to redline.
Old 12-16-2004, 07:03 AM
PreludeSiTdriver's Avatar
I have that same problem. I am running the Drag mani wih a 35mm wastegate. It suppose to be set at 10psi but it spiked up to 15psi. I hate that. I mean what can be done for this?
Old 12-16-2004, 07:21 AM
b00sted4dr's Avatar
Default Re: drag manifold w/ 35mm tial wastegate???? (PreludeSiTdriver)
where is your vacuum line for your wastegate connected to?
Old 12-16-2004, 07:49 AM
you can try to make a venturi in your exhaust where you connect your WG to. that will suck the gasses out of your WG
its not ideal but i think ill work! Good luck!
GetawayInMoscow
09-12-2007 12:43 PM
EJ1 wilcox
07-01-2005 07:57 AM
*Boostwerks*
04-14-2004 03:18 PM
ineedhelp
04-13-2004 10:16 AM
Quick Reply: drag manifold w/ 35mm tial wastegate????
