DOES THIS SOUND GOOD FOR A BEGINNER TURBO KIT...WHAT AM I MISSING?
1. used T3 turbo -
2. HF turbo manifold -
3. Vortech FMU - (WOULD I NEED THIS IF I HAVE A VAFC HACK?)
4. Eclipse OEM intercooler -
5. Eclipse OEM blow off valve -
6. Synapses “Missing Link” - (WHY WOULD I NEED THIS IF I HAVE A VAFC?)
7. Piping for intercooler and exhaust -
8. Oil supply and oil return lines -
a. Includes taps, splitters and flanges.
9. Miscellaneous bolts and gaskets -
10. Silicone braces
10. Silicone braces
Re: DOES THIS SOUND GOOD FOR A BEGINNER TURBO KIT...WHAT AM I MISSING? (jh)
this was my old setup... replace and remove anything u don't want/need
Turbo Kit:
>Garrett T-3 Turbocharger (.60A/R, 60-trim comp, .48A/R turbine)
>South Florida Performance Turbo Manifold
>South Florida Performance Downpipe
>Drag Piping
>Drag Intercooler (Overall Size 27"x7"x2.5")
>Greddy Type-S Blow Off Valve
>Tial 35mm .45 Bar Wastegate
Fuel System & Tuning:
>Apex'i V-AFC
>DSM 450cc Injectors
>88-91 Injector Resistor Box
>255lph Walbro High Pressure Intank Fuel Pump (FPH003)
>Calterm GM Injector harness clips
>NGK R5671A-7 Spark Plugs (0.032 gap)
Miscellaneous:
>Oil Feed Kit:
- Brass 1/8" NPT Tee Fitting
- 4ft of -4AN hose
- 1ft of -4AN hose
- (4) -4AN straight steel hose ends
- (2) aluminum 1/8" NPT to 4AN fittings
- 90 Degree 1/8" NPT to 4AN fitting
- Steel 1/8" NPT to 4AN fitting
- (2) Earl's 1/8" NPT to -4AN adapter
- Autometer 1/8 in. NPT to 1/8 in. BSPT Mech. Oil Pres. Gauge Adapter
>Vacuum hoses (4mm and 6mm)
>2.0" & 2.5" heavy duty radiator hose from NAPA (substitute for silicone couplers)
>1/2" NPT T3 Oil Drain Flange
>Greddy Type-S Blow Off Valve Flange
>-10AN Oil Return Line Kit
>Garrett T-3 Turbine Housing Inlet Gasket
>Garrett T-3 Turbine Housing Discharge Gasket
>Garrett Oil Drain Gasket
>Tial Wastegate Flange
>Deltagate/Tial Gasket (2)
>Earl's 1/2" NPT to -10AN adapter
>Earl's -10 AN male, aluminum, natural finish weld fitting
Turbo Kit:
>Drag Piping
>Apex'i V-AFC
>DSM 450cc Injectors
Miscellaneous:
>Oil Feed Kit:
- 4ft of -4AN hose
- 1ft of -4AN hose
Re: DOES THIS SOUND GOOD FOR A BEGINNER TURBO KIT...WHAT AM I MISSING? (CivicRyda2k)
you can take out all the stuff that is unecessary for ur setup
lamboextreme
01-09-2007 08:46 PM
marino1982
01-08-2005 09:45 AM
B18 CYA
04-21-2004 02:49 PM
