does it matter if i have all 4 bolts onto the turbo to manifold?
New User
i got 3 in but the 4th one i have to tighten and get from the outside or else when its on the car.. i can't get to it at all... but when i have it tightened on the outside.. i can't fit the turbo/manfiold both in at the same time because of my fludyn radiator. i'm trying to avoid taking the radiator out too... i put the copper high temp sealent around the turbo/mani..
Re: does it matter if i have all 4 bolts onto the turbo to manifold? (Integra_Boi)
Depending on what bolt your missing, you might have a manifold leak. Because on the inline pro manifold, I believe there are 2 holes that actually go right into the exhaust chamber.
Re: does it matter if i have all 4 bolts onto the turbo to manifold? (BG Boost)
As long as your not leaking your fine
[Modified by SO3Burner, 9:52 PM 7/21/2002]
You have to tighten all the bolts from the turbo to manifold off the car. Install as one piece.
You may have to take the radiator brackets off and lean the radiator up towards the passenger side.
Re: does it matter if i have all 4 bolts onto the turbo to manifold? (dustin)
yes, you need to make sure them bolts are very very tight, I learned it the hard way....
so you need to do it off the car, then insatll it as a whole turbo and manifold...
take out the AC fan, it'll help a lot and give you more room..
stan
stan
New User
Re: does it matter if i have all 4 bolts onto the turbo to manifold? (Flamenco-NA)
thanks guys for the input.. i might try to take the brackets off and move the radiator around.. this stuff is heavy from the top or bottom... i can't wait to do the clutch
New User
ok guys.. that radiator back trick worked pretty good... i put all 4 bolts in now.. thanks
chuckd05
04-16-2002 04:55 PM
