Does the HX35W make any good power? help!?
Hey guys im planning on buying Tallkyle's turbo Hx35w, Does anyone know if i will make 450-500HP with this turbo? because thats my goal. Here is the link to it. I have a sleeved and built B16 with 9;1 CP pistons. Ram horn turbo manifold.
http://hondamarketplace.com/showthread.php?t=2476340
Re: Does the HX35W make any good power? help!?
Holset HX35
Designed primarily for 6 cylinder engines of 5.0 to 6.5 litre capacity, the Holset HX35 turbocharger has higher flow aerodynamics capable of providing up to 0.46 kg/s at 3.0:1 pressure ratio.
A number of compressor and turbine options are available all featuring excellent map width, pressure ratio and efficiency.
Enhanced durability compressors are available.
yup it will make that power, theres more info in the holset thread but i believe its around the 60lbs mark, so similiar to the 60-1, sc61 etc... the cm2 of the exh housing is important too, something larger than the 9cm2 mark would be good for your goals.
its a 16cm exhaust.
will my 82.5mm B16 be able to power this turbo ok? Or is this turbo to big and will it lag because of that?...
Anyone know where i can buy a brand new 9cm or 12cm housing?? and if i do change the housing will i have to change anything else? im still new to this! thanks for the INPUT guys!
The TWO main reasons im buying a different turbo, I want one that will make 450-500HP and i want it to be at full boost if possible 3,5-4kRPM so will changing the housing help that spool?
Not sure if this is a dumb question or not but do the Holset turbo's use external wastegates or are they internally gated?
^Internal wastegate, but you can run an external wastegete on it with no problem. Just weld the flapper shut and you're good to go external wastegate.
b18cgsrturbo
02-24-2018 04:29 PM
VNTEC
12-10-2003 10:41 PM
