Do you really need a 255 Fuel Pump with 5psi of Boost?
I have a Drag 4 Kit installed on a 94 Accord. I wanted to know with 5PSI of Boost do I really need to have a 255 Fuel Pump.
The Walbro intank Fuel Pump is very loud. |
Re: Do you really need a 255 Fuel Pump with 5psi of Boost? (abeaujuin)
It's not "will the pump do for only 5psi", it's "can I keep myself from turning up the boost" you need to really be asking.
Besides, don't DRAG kits use FMU's? 150psi @ rail + stock pump = bad bad things http://images.honda-tech.com/set1//smile/emcrook.gif |
Re: Do you really need a 255 Fuel Pump with 5psi of Boost? (VTC_CiViC)
Walbro 190 lph high pressure would probably be perfect for low hp boosted apps. You definately don't want to run an fmu on a stock fuel pump
Yes, u need the pump.
Re: Do you really need a 255 Fuel Pump with 5psi of Boost? (SpdFrk)
abeaujuin, if you will ever run over 50psi line pressur eat any time for any reason, then, and only then do you need a 255lph. The only - I repeat - only difference in a 190lph pump and a 255lph pump are the flow rates over 50psig.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC »</TD></TR><TR><TD CLASS="quote">It's not "will the pump do for only 5psi", it's "can I keep myself from turning up the boost" you need to really be asking.
Besides, don't DRAG kits use FMU's? 150psi @ rail + stock pump = bad bad things http://images.honda-tech.com/set1//smile/emcrook.gif </TD></TR></TABLE> what kind of math are you doing? 5psi x 12 + 38 + 10 = 108 not 150+ https://honda-tech.com/forums/images...s/emsmilep.gif |
