Do these valve cover vents pose a problem?
Well.. I didnt have the manifold when I had the fittings drilled for the VC.
Are these too close to the manifold?
I didnt want to wrap the manifold with heat wrap, but it looks like I might not have a choice - maybe get some fire sleeve and slide it over the whole fitting?
thanks
thanks
Re: Do these valve cover vents pose a problem? (Timmay)
It's not - there is roughly 1cm clearance with the tube part of the fitting, and about 3/4cm for the hex part of the fitting
Re: Do these valve cover vents pose a problem? (B18EG6)
im not sure how much heat those fittings can take.. putting the sleeve over it like you said should work though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">im not sure how much heat those fittings can take.. putting the sleeve over it like you said should work though</TD></TR></TABLE>
sounds good - They are -12 fittings so I will probably get -16 sleeve to ensure it fits over the hex piece.. or maybe search mcmaster for some ideas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull »</TD></TR><TR><TD CLASS="quote">youre fine... vc looks great too.. i like the wrinkle. did my h cover witth the vht as well...took ******* FOREVERto dry to the "hard" finish it has now. i didnt sand the top of the embossed lettering on it either, so its all black...looks kick ***. I have my -10 vents on the rear of my vc (under the baffle, so no gravity slosh)... turned out great.
i wouldnt worry about it youll be fine... </TD></TR></TABLE>
Thanks! The cover was actually powdercoated by a member on here - I got my brake calipers, slave cylinder, and now my valve cover done through him I tried some wrinkle paint but couldnt achieve the flat finish so I figured I would powdercoat it!
