do these look like 9:1 pistons?
do these look like 9:1 pistons for a b16a? they should be JE SRP part #149216... please let me know what you think
Re: do these look like 9:1 pistons?
i think the SRP uses a different dome/dish design, im not to sure, the box matched the part number i ordered for 9:1, but something makes them look different to me...
I just spoke with alex at je and he said it should still be 9:1, they look like a higher compression, because they use a bigger valve relief, which requires a slightly larger dome to compensate for the lack of surface area....
most off the shelf flat top pistons will be 9:1 in a b16a block and just under 10:1 in a B18a/b/c block. Keep in mind the combustion chambers in the head will make a slight difference also.
Yep, those pistons boostedcivicsir posted look like they'd be 9:1 in a 1.8 block, and around 8.0:1 in a B16.
EVOCELICA
03-16-2003 12:31 PM
