DIY turbo 4-1 merge collector How to cut the tube?
I want to know how should I cut my tube to fit the 4-1 merge collector
tks for your help
tks for your help
Re: DIY turbo 4-1 merge collector How to cut the tube? (Garrett)
Its pretty tricky. I figured it out after about 5 hours of staring at the thing. I dont know if it should be spread around the board though, after all this is a way a few of our H-T friends make thir livelyhood. Just stare at the pic, you can figure it out.
Rob
Rob
Re: DIY turbo 4-1 merge collector How to cut the tube? (rjardy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy »</TD></TR><TR><TD CLASS="quote">Its pretty tricky. I figured it out after about 5 hours of staring at the thing. I don't know if it should be spread around the board though, after all this is a way a few of our H-T friends make their livelyhood. Just stare at the pic, you can figure it out.
Rob</TD></TR></TABLE>
Do you really think this would be an issue? Like some kid is going to see how to cut the pipes for the collector and not BUY a manifold but make one instead?!? In general I don't think any one would lose any manifold sales if 'the cat was let out of the bag'.
We probably shouldn't talk about how to do engine swaps because some people on HT make their living doing it, right
Your the grinch who stole the tech from honda-tech
Re: (Garrett)
Seriously.. you have a 2" opening at the bottom and full tubes at the top.. Take the with of the flange opening.. take the width of your two tubes.. find the difference and divide by two.. then that is the amount that needs to come off the end of each.. To get the angle you just figure where you want it to end and put a mark.. Say 4" up the 5" pipe. Mark it.. Then cut from point a to point b.. You then do it for the other side.
Does my explanation really help? Don't tell me you couldnt figure that much out on your own? Having a good band saw will make your life alot easier..
Re: (evoeone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evoeone »</TD></TR><TR><TD CLASS="quote">cutting seems liek teh easy part, the hard part is getting teh TIG torch in there</TD></TR></TABLE>
werd...
even with the baby cup and back cap i get uber-frustrated trying to get the torch in between the runners and crap...
werd...
Re: DIY turbo 4-1 merge collector How to cut the tube? (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">
Your the grinch who stole the tech from honda-tech</TD></TR></TABLE>
Boo flippen whoooo
take your and put it somewhere else.
If you have been around this board for a while like some of us, you may fathom the amount of drama that this brings up. Its just a good idea to steer clear from it. Try not to get all but sore about what I said, im just drying to take the DRAMA OUT OF Drama-Tech.
Your collector looks good BTW, actually i miss read your post, i thought you were having issued with the collector, thats the hard part
Rob
Boo flippen whoooo
Rob
Drama has already started now, hehe
here are some websites with merge collectors, couldnt find any that teach u, just practice practice practice
http://www.popularhotrodding.c...urns/
http://www.carcraft.com/techarticles/0304_merg/
http://www.burnsstainless.com
http://www.secureperformanceor....html
http://www.ssheaders.com/Collectors.htm
http://www.full-race.com/collector/
Re: DIY turbo 4-1 merge collector How to cut the tube? (LSturboHB)
Dude if you can't figure out how to make a freeking collector then you stand no chance of making the rest of the manifold. This is not that tough.
Re: DIY turbo 4-1 merge collector How to cut the tube? (shortyz2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz2 »</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
booooooooo yaaaaaa, that thing is awesome
Re: (Garrett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett »</TD></TR><TR><TD CLASS="quote">This is the final result, I dont understand how to cut the tubings
</TD></TR></TABLE>final result?did you do that,thats pretty good.
Re: (accordfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordfreak »</TD></TR><TR><TD CLASS="quote">try using cardboard and practice cutting it to the way you want it...
merge it together using tape and see if it matches up</TD></TR></TABLE>
my friend did that .. i go the whoel idea but its pretty easy to make it perfect iwth some scissors instead of using a saw to achieve the same results
