Re: Discussion Topic: Let's talk Intercoolers!!
I have a PWR Intercooler. From my research they are rated on WHP Vs. Crank HP... Mine was rated at 475whp. Which im at about 410 now w/o no2
I Hear they are excellent intercoolers, but are expensive. I do not have a picture on me. I believe it was 31X6x3.5 |
Originally Posted by blackeg
(Post 47654134)
well then....i should have done more research before i bought my 600hp precision intercooler. i guess im gonna have to start shopping around to upgrade
Originally Posted by TheShodan
(Post 47654760)
Let me know. I can help, but this is why this thread exists, to help you make an informed decision
What would be a good budget minded fmic that will handle my 4-450 whp goal? My fmic got pretty hot at the inlet but is usually pretty cool at the outlet. It got a ton better after wrapping my manifold since it sat so close to the intercooler. Its warm at the inlet at still cool at the outlet....should i leave it be for now?
Is an analytical perspective welcome here? Back when I had free time I did quite a bit of end tank and intercooler core modelling.
Originally Posted by Leebro61
(Post 47656742)
Originally Posted by scottdh20
(Post 47656724)
Don't worry, it's coming.
(Post 47657162)
I use PWR intercoolers on all of my builds... Just can't beat the quality IMO... Yea they are expensive but worth the price.
Im using a 24x12x3 core on my EJ8 project with centered 2.5" endtanks. I've also got a PWR 24x9x3 core sitting around that has no endtanks, might make it a dual backdoor and keep the larger PWR for my 700RWHP S13 project. |
Here’s a small write up I made about the differences. I want to thank Johnny Wang of Spearco for helping me out with this.
An intercooler's “magic” centers on air density. During compression, charge air is heated and with this heat comes a decrease in air density. Density can be viewed as the amount of molecules in a given volume of air. Intercooling reverses the heating trend and endeavors to recapture some of that density. http://img.photobucket.com/albums/v2...urboworks2.gif The amount of density regained depends on the ambient temperature of the air (in air-to-air units), the efficiency of the compressor (max boost, wheel efficiency etc.) and the cooling capacity of the intercooler. A properly sized turbo that operates at or near its peak efficiency will not heat the charge as much as a mismatched unit that has to overspeed to generate the desired boost. This extra effort results in a chopping of the air, which nets high outlet temperatures.Because of its charge chilling capabilities, the intercooler also ups the detonation threshold and, as a general rule, a good intercooler will allow you to run three to four more psi without experiencing any detonation. Tube-Fin Intercoolers Let’s look at the tube-fin designs. These include the higher end companies of GReddy, HKS, and PWR. The lower end ones , which require a lot of surface area in order to cool, are the CX Racing, Johnny Race car, Godspeed, etc. Typical tube-and-fin units utilize extruded tubes with fins pressed into place. In order to achieve strength, a thick, extruded tube must be used. The picture below shows a fin comparison with the popular low-pressure drop, high-speed plain square fin used in CX Racing, (right) and an offset fin design used in GReddy (left) . The offset fin will allow the air to travel slower through the core (more pressure drop) but the air will have more time in the core for heat exchange. Apexi’s Delta Design also uses an off-set design that works extremely well. http://image.turbomagazine.com/f/165...comparison.jpg The tube-and-fin core is held together and its seal is created at the joints at the end of the plates, which is usually .125 inches thick. The width of the tubes is less than the width of the side plate. Space is lost where the joints for sealing are used. So a 3.5-inch core will have tubes only 2.87 inches wide. Tube and fin has a larger leakage rate compared to bar-and-plate cores. Furthermore, tube-and-fin cores are more susceptible to road damage from rocks and debris than bar-and-plate cores; big trouble in front-mount applications. The oval tubes are extruded from thin-wall material and any sort of extreme pressure can cause these tubes to 'balloon.' But that is extremely rare, and only if the quality is ridiculously poor. But they are very inexpensive to make, and given the right amount of surface area, can do a great job of cooling. But they have to be pretty tall in order to do it correctly. The smaller ones under 7" in height really only can do about 350whp, then its about done. Even the taller ebay ones have to be big to work properly.... but they can work properly provided it was constructed without leaks. Bar & Plate Intercoolers. Ok.. Bar & plates.. Everyone’s favorite. Many companies started doing Bar & plate intercoolers after Spearco and Garrett (and their vendors) rocked the house with their designs. They started improving their designs even more as of 2008-2011, but in the meantime, companies like Precision (who used to use Spearco), Mishimoto, Treadstone, and some private labels. On the ambient side, where oncoming air streams through the unit, fin design is equally important. Fin density here also impacts cooling performance but there is often the vehicle's cooling system to consider. This is a louvered fin system from a Garrett. The first versions for years had two rows of these fins in between the plates of the intercooler. Recently, they’ve been changed to where it has 3 rows of these fins sandwiched in. http://image.turbomagazine.com/f/165...uvered_fin.jpg Side split fin. – Used on some Bar & plate intercoolers. http://image.turbomagazine.com/f/165..._split_fin.jpg A Plain Square fin design from Mishimoto, some private label companies, Treadstone and Precision, (IIRC) http://image.turbomagazine.com/f/165...square_fin.jpg According to Wang, Spearco pioneered the bar-and-plate core design. True, the bar-and-plate design is a bit heavier than tube and fin, but this is actually advantageous. A bar-and-plate core can take the damage of front-mount life and endure high boost without flinching. Sealing is superior in bar-and-plate units because the bars and brazing sheets run the length of the unit, providing a 100-percent seal between the ambient and charge sides. A key advantage of bar and plate is its extraordinary variety of fin designs on both sides of the cooler. Further, the height of the passages can be changed by using taller bars and fins, which dramatically expands the possibilities for the intercooler designer. A 3.5-inch thick core gets a 3.5-inch row of fins, not the 2.87 inches found in tube-and-fin designs. Here’s the difference. Also, a tube-and-fin design has a lot of room between rows where a bar-and-plate unit can get more rows into a given area with more area per passage which means more cfm and a more efficient unit. As far as big boost goes, the ability of a bar-and-plate core to handle high boost is determined by the thickness of the braze sheets, fins, side bars and top plates. For Tube and fin, its much more about surface area that determines HP capability The thickness (and the type of fins used) dictates how quickly the charge air will move across the unit while the surface area affects how quickly ambient air will flow across the cooler. The curveball here is fin density. The number of fins per inch will dramatically impact the cooling characteristics of the unit. Mr. Wang states that Fin combination is very crucial when designing an effective core with a very low pressure drop, and that although a dense fin design offers superb heat transfer, this design also creates high pressure drop. Pressure drop is the amount of boost lost by the system as it pumps the charge air through the intercooler. The type of fin-plain, offset, louvered or bump-each has its own unique heat transfer characteristics. So how do you pick? Think about it. when choosing any intercooler, the key is that a balance is met where the effectiveness is attained and a low-pressure drop is achieved. For example, a plain fin design offers an exceptional low pressure drop but does not provide great heat transfer compared to a louvered fin or an offset fin. The air moves quickly over/through the plain fin (low pressure drop), but is so fast it may not be in the core long enough to maximize heat transfer. Consequently, air moving through a louvered or offset fin takes longer to move through the core (more pressure drop), but it also has more time to transfer heat. Surface Area vs. Thickness of an intercooler Ok.. So now you’ve got the right type of intercooler you want.. which is better, to be thick or to have large height? While not trying to snicker thinking I’m on an ENZYTE commercial, I think of this rule of thumb. The rule of thumb here is actually rather obvious; bigger is better. More surface area means more cooling power. However, a larger surface area is favored over a thicker core. A larger surface area provides more cooling face for the ambient air where a thicker core might be less effective. As the core gets thicker, the ambient air traveling through the core is heated by transfer and the farther through the core it travels the hotter it gets. By the time the ambient is at the back side of the unit, it's lost a good percentage of its cooling capacity. Beyond that, thick cores cause an ambient pressure drop, which means less air will make its way to the radiator causing overheating issues Wang agrees with this concept. He states that when it comes to area, achieving the maximum height is more beneficial than widening the unit. The main reason for this is pressure drop is greater when the charge air has to travel through longer passage compared to a shorter passage. It should be noted that pressure drop through a longer-passage core can be compensated for, to a certain extent, via fin design. With bar and plate being so superior, one has to wonder why even bother with Tube/Fin setups. Its very simple; It's all about cost. The tube-and-fin core is much cheaper to produce and is often used in OE applications, which inherently run lower boost levels. So remember, gents, Intercoolers do a lot more than look good behind a custom bumper cover. Their atmospheric magic is the result of technical factors such as area, thickness, fin design and fin density. Controlling the flow compromises and cooling advantages of these factors will determine the ultimate driveability of your turbocharged beauty. |
^^^^ top notch info. thanks!
Old school Garrett core 24x8x3.5 crew checking in!
very informative when selecting your next intercooler
Originally Posted by TKERacer619
(Post 47646918)
(Post 47657809)
(Post 47659048)
I measured the core and its 20x7.9x3.5". On their website it shows 450hp max. The Shodan you said they improved on their design around ~2008. Do you think the hp rating that it shows on their site is roughly the same as what I have or no? Looks like I will be upgrading in the near future if I want to go past 450 regardless.
here a full-race dual backdoor intercooler I turned into a single backdoor by cutting off and blocking the end off, because it did not allow the use of the original radiator location, hope it wont affect the efficiency .
https://img827.imageshack.us/img827/8036/img0679jx.jpg chassis completed https://img809.imageshack.us/img809/3908/img0680i.jpg |
(Post 47659048)
Nice setup, but that oil cooler needs to be in another spot, not behind the radiator. |
(Post 47659211)
you can put it in front of the intercooler on the drivers side, that way the charge air is still cooled by ambient air flow...
or you can buy a duct and a fan on ebay and have them rigged to a thermostat to come on, that way you can just shove the oil cooler behind the bumper cover out of the way |
very cool thread
Originally Posted by turboda4dr
(Post 47661431)
https://img.photobucket.com/albums/v...a/IMGP0682.jpg https://img.photobucket.com/albums/v...a/IMGP0683.jpg |
I will attemp to do it like that, thanks for the suggestions, but if it don't work out, hope it will be fine like this.
(Post 47661431)
http://img.photobucket.com/albums/v8...a/IMGP0682.jpg
http://img.photobucket.com/albums/v8...a/IMGP0683.jpg |
