Difference between Iridium BKR8EIX and V-Power R5671A-8 NGK Spark Plugs.
Old 08-30-2005, 08:18 PM
dunkd's Avatar
Default Difference between Iridium BKR8EIX and V-Power R5671A-8 NGK Spark Plugs.
Both 8 heat range... the bkr is an iridium plug which costs 3x as much as the normal vpower. In normal lamens terms what is the difference? Not the mombo jumbo they say on the website, and with the difference how does it apply to our cars?
Old 08-31-2005, 05:57 PM
dunkd's Avatar
bumppp
Old 08-31-2005, 07:56 PM
dunkd's Avatar
bump
Old 08-31-2005, 10:32 PM
sharkcohen's Avatar
Default Re: Difference between Iridium BKR8EIX and V-Power R5671A-8 NGK Spark Plugs. (dunkd)
R5671A-8:
copper center electrode, 14mm, 3/4" reach, 5/8" hex, gasket seat, projected tip, non resistor, V-power (v-grooved center electrode)
BKR8EIX:
14mm, 3/4" reach, 5/8" hex, gasket seat, ISO length, resistor, projected tip, fine wire (0.6mm) iridium center electrode, tapered cut ground electrode
Old 09-01-2005, 08:58 AM
dunkd's Avatar
yah i know the physical differences, but what do they mean in a honda application?
Old 09-04-2005, 03:03 AM
aziz93's Avatar
Default Re: (dunkd)
great thread
Old 09-04-2005, 07:33 PM
pgpunkguy's Avatar
Default Re: (aziz93)
iridium has a higher melting point than any other spark plug material (including platinum). it is also MUCH stronger... the smaller fine wire tip means you'll have less possibility of spark jump.
pratically speaking, it just means your plugs will last longer and ignite more consistantly than platinum plugs.
Old 09-04-2005, 09:52 PM
JDogg's Avatar
Default Re: (pgpunkguy)
you need to make sure to use a resistor type plug.. almost all the ngk r-series plugs are non resistor. non resistor can lead to coils and ignitors burning up.
we run the bkr8 and 9eix in damn near everything with exelent results
raverx3m
02-13-2016 05:28 PM
dunkd
07-05-2006 06:35 PM
hondapwr
23
05-10-2006 07:10 PM
vtec.dc2
09-03-2003 06:00 PM
Quick Reply: Difference between Iridium BKR8EIX and V-Power R5671A-8 NGK Spark Plugs.
