did ignition timing cause me to blow? (check out my timing maps)
setup described in the sig, it lifted the head and caused the threads for the head bolts to strip (at least 3 of them), making the block garbage. whats weird was i didnt hear any detonation..... but could somebody point me in the direction of where my timing maps should be using a full y8 motor this time around?
ignition low cam
ignition high cam
ignition low cam
ignition high cam
Re: (fox three)
Yes, the ignition timing is the reason why you blew your engine. Download Crome or Uberdata and open the P2P aka D16Y8 ignition maps. It runs 16.75* of ignition timing at WOT NA in the high cam. You are running the same amount of ignition timing at ~10psi.
http://forum.pgmfi.org/viewtopic.php?t=6546 <-lots for you to read.
Re: (fox three)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fox three »</TD></TR><TR><TD CLASS="quote">I'm a bit confused.
Why are you blaiming timing for lifting the head?</TD></TR></TABLE>
detonation, or causing big cylinder pressures causing it to pick it up
Re: (grubere)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grubere »</TD></TR><TR><TD CLASS="quote">
http://forum.pgmfi.org/viewtopic.php?t=6546 <-lots for you to read.</TD></TR></TABLE>
BINGO.
you are my hero
BINGO.
you are my hero
Re: (2muchboost2blow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2muchboost2blow »</TD></TR><TR><TD CLASS="quote">BINGO.
you are my hero </TD></TR></TABLE>
my ignition tables were not like a stock y8 but runs fine
Modified by igo4bmx at 9:06 PM 3/3/2006
Re: (igo4bmx)
The whole D16y8 map is a mystery for the most part. It really doesnt make sense. No one has shown the inititive to actually sit down and figure out whats going on. I will say that running the imported Y8 map has reduced the number of people suffering from said issues dramaticaly. I also dont agree with a lot of things said in that y8 thread i posted earlier as none of them bothered to play with the car on a dyno or with an advanced timing light. The butt dyno is not anything worth basing an opinion on.
Eh, whatever. Personally I suggest running the d16y8 map as is. tweaking it to run correctly. But dont do any of this nonsense changing the idle portion and advancing the dizzy. It doesnt make sense. Don't do it.
Re: (i.leik.noodels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i.leik.noodels »</TD></TR><TR><TD CLASS="quote">oh wow, man isn't that what neptune looks like? how did you get a copy?
it's not neptune
it's not neptune
eortizr
09-02-2005 04:20 AM
