Did I choose the right turbo for my application? (GT3076RLE)
I have a B16A with Eagle rods (HD), Weisco pistons (9.0-1). Looking for streetable power around 300whp. Did I go with a turbo that will work for what I'm looking for? Thanks!
Re: Did I choose the right turbo for my application? (jdmvtec28)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtec28 »</TD></TR><TR><TD CLASS="quote">You could have gotten away with a GT2871 and had a little quicker spool time.</TD></TR></TABLE>
+1
Car: Eg civic coupe
Engine: GSR with 0.020" 9:1 CP pistons, Manley rods, OEM bearings, ITR intake cam, GSR exhaust cam
Mods: EL manifold, Tial 38mm wg, 3" v-band dp, 3" exhaust, Custom IC piping, Large front mount, RC 750cc injectors, Walboro 255lph pump, AVCR boost controller, Edelbrock IM, Edelbrock Tb, stock b-series throttle, GT2871 w/.82a/r housing
17psi on pump gas
24psi on 110 octane
*Injectors were running at 95% duty cycle. I had to detune the higher rpms to not make as much power. With more fuel, this could have easily made 450whp.
+1
Car: Eg civic coupe
17psi on pump gas
24psi on 110 octane
Re: Did I choose the right turbo for my application? (0x64)
0x64!!
Nice numbers! I'm gong to see Jeff on the 6TH. Hope to get good results like you did.
Re: Did I choose the right turbo for my application? (otto)
It's actually a customer of Jeff's, ?John Lozada?, but I figured I would post it to show what it's capable of. 250whp @ 5,000RPM
What kind of fuel pressure were you running? I heard you could support 500-550 whp with 720cc injectors at 50psi? I would like your input on this. I am runnning these injectors with a GT30R on a "street" car. I still want reasonable gas mileage and decent resolution on my map.
Re: Did I choose the right turbo for my application? (crazyitr)
save some money and go with a SC50 or a SC34 you can make 300 with these turbos easy, but they lag a bit more then a ball bearing turbo, but they are cheaper
Hrm I was also looking and am torn between an GT28RS with T3 .82 drop in vs the GT30R... I couldn't really find much dyno plots of the b16 with GT30R nor the B16 within the stock map sensor limit. Almsot want to go GT30R just cause it's got the ported shroud... lol. On my SC34 boosting 10 PSI I hit full boost at about 5000-5500. 1psi at about 3500. Will I see much gains running the GT30R over this in spool time and overal powerband?
Re: (Tchleung)
I have an appointment with Jeff to tune the car. I decieded to use Neptune for a tunning format. I'll post the dyno runs when I get back.
Re: (Tchleung)
I ended up going with the GT3076RLE. My appointment is set for April 6th @ 10:am. Hopefully I'll have a post of my venture that night.
Re: (Tchleung)
We hit full boost in our evo with the same exact setup on Justins car by 3k !!!!
we never got to Really power tune the car, but we did make 400 whp on a fairly basic tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 »</TD></TR><TR><TD CLASS="quote">
+1
Car: Eg civic coupe
17psi on pump gas
24psi on 110 octane
*Injectors were running at 95% duty cycle. I had to detune the higher rpms to not make as much power. With more fuel, this could have easily made 450whp.</TD></TR></TABLE>
damn alpha, you must have like every dyno in the world!!!!!!!!!!! i mean every single turbo anyone asks about, you have a plot for them, round of applause for my boy! hookin us all up thanks bro!
+1
Car: Eg civic coupe
17psi on pump gas
24psi on 110 octane
Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">TTT!
Otoo, did you ever get some numbers? how did you like the GT3076RL?</TD></TR></TABLE>
I need to set up the appointment this week. I'm dieing to get my car in the road.
nice turbo, but seems a lil big for your power goals....I also agree that the gt2871r would have been a lil nicer even the sc50 and sc34 but you def. have tons of room to grow with the one you picked out
tmkpres
03-08-2004 05:44 PM
