Deburring piston ring.
What do I use to deburr the end of the piston ring I just filed?
Re: Deburring piston ring. (MidShipCivic)
i used 400 grit sandpaper
Re: Deburring piston ring. (Bailhatch)
Thanks for the info any more advice? Like how to do it (technique) .
Make sure you sand, or if you use a fine file, to stroke verrrry lightly and to stroke away from the gap.
Re: Deburring piston ring. (Blang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blang »</TD></TR><TR><TD CLASS="quote">Make sure you sand, or if you use a fine file, to stroke verrrry lightly and to stroke away from the gap.</TD></TR></TABLE>
Thanks #1st time poster welcome to H-T. https://honda-tech.com/forums/images/smilies/emthup.gif |
here's where i got the idea. I went over all the edges of my rings as well with 400 but i didn't use a scuff pad to remove any coating like this guy. http://www.circletrack.com/howto/4639/
Great link, thanks for your time Bailhatch https://honda-tech.com/forums/images/smilies/emthup.gif .
I use a very fine knife sharpening stone. Just hit the edges
Re: Deburring piston ring. (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">I use a very fine knife sharpening stone. Just hit the edges</TD></TR></TABLE>
Thanks for the advice. Interesting tool for the job http://images.honda-tech.com/set1//smile/emcrook.gif . |
In the old days, engine builders used to use large stones to smooth out the surface of the rings to achieve a better seal between the ring and the piston ring land. Now days rings are much flatter from the manufacturer.
The sharpening stone sounds like it would be easier to use than the sandpaper. good idea https://honda-tech.com/forums/images/smilies/emthup.gif One of those little stones, like 1" x 4" x 1/4", would be perfect I bet.
That is what I use, works good for me
| All times are GMT -8. The time now is 08:46 AM. |
