DC4 stock block LS-T 18lbs pump gas whp results - Dave lee tuned
Do you even PLEBE R8?
Well ive never posted my car in the FI sub-forum but will now since i feel its worthy of a post for us NON-VTEC gents out there. Well here goes:
Max power: 393whp Max torque: 300ft/lbs
18lbs pump gas
Car: 94 LS Integra
Setup:
-Stock block
(B18B w/ 165k miles not rebuilt)
-OBD2 spec oil pump
-GSR timing belt
-GSR water pump
-ARP head studs
-Top end:
-Port and Polished PR4 head
-JGE 303 all motor cams
-Crower dual valve springs/titanium retainers
-1mm oversized ferrea valves w/ 5 angle valve job
-Factory ignition system w/ NGK BKR7E plugs
Custom pieced together turbo kit:
-Garrett t3/to4e 57 trim w/ .63 ar
-Akimoto high flow turbo spec filter
-AFI equal length mani
-3" Turboback exhaust w/ Apexi turbo spec muffler + Kteller resonator
-Tial wastegate w/ 12lbs spring
-Turbosmart MBC set at 18lbs
-Streamline intercooler piping w/ greddy type rs bov
-Blox intake manifold and thermal gasket
-Blox 66mm throttle body
-Treadstone TR8 Intercooler
-Godspeed half core radiator w/ 12" slim fan
-750cc Deka Injectors provided by a 255 walbro fuel pump
-Blox FPR modifier
-Omni power 4 bar map sensor
-KMS Catch can breather- earls hose + summit fittings
-tuned by Dave Lee using CROME pro
18lbs pump gas
Dont have any current pictures of the car but will take some this weekend using my gf's camera since i dont have one.
Modified by ForceFed Motorsports at 7:43 PM 6/5/2008
Modified by ForceFed Motorsports at 7:47 AM 6/6/2008
18lbs pump gas
Car: 94 LS Integra
Setup:
-Stock block
-OBD2 spec oil pump
-GSR timing belt
-GSR water pump
-ARP head studs
-Top end:
-Blox FPR modifier
18lbs pump gas
Re: DC4 stock block LS-T 18lbs pump gas whp results - Dave lee tuned (ForceFed Motorsports)
nice power. how your ls-t feel on the street and have u took your car to the track......
Re: DC4 stock block LS-T 18lbs pump gas whp results - Dave lee tuned (hbyrd8701)
3rd gear just smokes the tires but 4th is solid, especially on the freeway feels crazy. Going to the track next friday after i get some wheels for my slicks
Re: DC4 stock block LS-T 18lbs pump gas whp results - Dave lee tuned (Silva Bullit DC4)
Redline is at 8k rpms right now, justin aka Turbo-LS had revved his to 8600 rpms but was still making power. Sorry for the bad pic of the sheet dont have a scanner and was using a picture phone lol.
Did it make that much power or did it have a boost spike at the top end? Or is it wheel spin? looks good though.
Re: DC4 stock block LS-T 18lbs pump gas whp results - Dave lee tuned (8herout)
I know no one believes it but YES it made that much power Have a few other print offs of him working up to that much power. Was making 363whp at first pull and stock redline. Made over 400whp with a boost spike though lol.
Edit: Added engine mods which allow me to rev over stock redline safely i forgot to mention.
Pretty impressive with a stock block ls, that head must flow very well. I'd throw some arp rod bolts on that bottom end tho just to be on the safe side
Re: DC4 stock block LS-T 18lbs pump gas whp results - Dave lee tuned (blwn95civic)
I got them just sitting in my garage. Probably wait till this block takes a dump then use em in the next one.
i'm scared to take my ls head that high. i have crower valvesprings + retainers. the rocker arms just scare me, doesn't take much to make them pop out.
Re: DC4 stock block LS-T 18lbs pump gas whp results - Dave lee tuned (ScorpioMk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScorpioMk »</TD></TR><TR><TD CLASS="quote">did dave get on bangbros while tuning....</TD></TR></TABLE>
He took my car to the dyno while i was working so i dunno.
Thanks for the comments guys, did a cold start yesterday and even without the FITV dave got my car to idle almost stock from 1600 down to around 1000 rpms
Re: (civicsitek GanGsTa)
Didnt make it to the track, but did make it 10 hours of driving to portland and back in the same day for the NW h-t meet and didnt blow up
Cars nothing special but is fun to drive, just not long distance
Ugly *** manifold looks like shiet Getting coated after this failed attempt.
Modified by ForceFed Motorsports at 10:14 AM 6/15/2008
hybrdthry911
11-18-2009 08:58 PM
