DaX's D16Z6 turbocharger build - older, but maybe not any wiser
#201
Re: DaX's D16Z6 turbocharger build - older, but maybe not any wiser
Congrats! Sounds 5x5 so far. I don't know how the disconnected coolant line for the iacv will behave in your case, I can adjust mine through Neptune. It acted silly, yeah, but I was able to fix it through the tune. Put a broken down and folded out cardboard box under your engine bay to spot any leaks, particularly the little ones.
I was hoping to start mine today as well but it's been raining for 3 days now. And slow progress due to that. Lol. Got most of the engine assembled in my kitchen, just waiting for dry weather to move it outside. Sigh.
#203
Your daughter looks super happy. Good job man. Sounds like the throttle stop needs adjusted up just a little bit. I like to set idle once the cars warmed up by unplugging the iacv when it's running then adjusting the throttle stop up till it idled at about 800-900rpms.
#204
#205
You figure out which wideband you're going with?
#207
#208
I have an innovate mtx-l and have had nothing but problems with it. All the aem widebands I've had have worked great over the years but the innovate throws a e8 with even a good o2 sensor.
#209
I bought a innovative kit and it’s worked flawlessly so far. Can’t remember what model at the moment but it was around $200.00
#210
That's why I passed on the MTX. I read there were numerous problems there. I was going to pass on the Innovate altogether because of this, then stumbled upon the LC-2. I didn't really see anything outside install troubles. The LC2 has been awesome, I've never had any troubles. There's probably more complaints about Bosch sensors than anything lol.
#211
Try changing the actual cable. We've been innovate direct for a while. I've installed a countless # of Innovate and AEM gauges over the years. The most repeated issue is just sensor failure, which it's just a Bosch sensor thing regardless of what wide band you choose. I've yet to see an actual gauge failure from Innovate, but I have seen the very random "bad cable" pop up. It happened in my own car after trying to trouble shoot it on and off for months. It ended up being the cable itself, something inside of it went bad giving the same error. I've only seen 1 AEM wideband gauge go bad. I was throughly surprised and appreciative of the support I got when calling AEM about the issue. The PLX gauges are also nice, I just haven't installed enough of them to have a "long term" opinion. Again, just my $.02 worth of ramble.
#212
I think we're trapped into only Bosch sensors though?
#213
Wow, appreciate all the input from folks on wide bands. I remember being a fan of PLX back in the day, and haven't really looked at any other brands since seeing they were still in business.
Do most folks that run these on their cars just do away with the 4-wire sensor and run the wide band full-time, emulating the narrow band signal? Or, are people utilizing a 2nd o2 bung and still running the narrow band? I was planning to only run the wide band and emulate the narrow band signal to the S300. Any drawbacks to doing it this way?
#214
#215
Bosch sensors are definitely finicky but, they will also fail prematurely if the mounting angle isn't within the correct range. I learned this first hand, thank goodness for warranty sensors.
#216
#217
#218
Yuppers. We spend a LOT of money shopping online for just about everything but groceries, and even purchase some hard to find grocery items from online sources. So reviews play a big role in that and reading them is a job unto itself. Lol! Most times it's just negative crap from either user error, or something broke/failed after considerable elapsed time. The vast majority doesn't even know HOW to properly review. Sigh.. Whole other topic entirely though. Lol
#219
As of now, I will have to pass emissions, but it's super lax compared to other states. I pull in, they look for a cat, put a sniffer in the tailpipe, and let the car idle for about a minute. That's it. My plan was to have a 3" cat and a matching test pipe, and to swap the cat in when I go in for the test every year. I was also wondering if I was running E85 if that's any better for passing emissions. Since I don't have to rev the engine up any during the test, I figured the turbo wouldn't even come into play. I was hoping that the wide band could put out a narrow band signal that the ECU can use and run in closed loop for the test.
And I say "as of now" because legislation has been passed to do away with emissions, they just need to figure out how to implement it, which they said may take about 3 years.
#220
The innovate wideband was literally new in box, used for under two hours on my all motor car on pump gas. If the cable is bad I'm not gonna dump any more money into it because, well honestly it shouldn't be. I'm just gonna go with aem. I've ran an aem wideband in well over 2000 cars over the years for tunes and all I've had to do was replace the sensor about once a year just to make sure it's in good working condition. I don't think I'll ever buy another innovate after reading up that allot of people have had the same issues and they say it can be due to a firmware issue as well, all in all, the aem wideband just works, no special features, just wire up power and ground to it and it works as long as the sensor is good working. I like the simplicity of it and it's about one of the cheapest as well.
#222
Yeah. Started my tuning business in 2010, on my last laptop I had over 1900 tunes saved on Crome alone and I've had my new laptop for about a year now and that's not counting tunes on s300, kpro, flashpro, hp tuners and tuner studios (megasquirt)
#223
My AEM was cheap simple and user friendly I get a replacement sensor from autozone. I had a innovative Lc1 it was more of a pain to install and use but it worked well. I’d go with AEM and use xenocron diy guide to install. Pretty easy job keep up the great work on the build.
#224
Thanks! Progress will be slower for the next few months until tax time, now that I have it running.
I cranked the car up and left it idling yesterday so it would warm up before I took it in for emissions (it passed). I heard a squealing noise from inside the house so ran out and shut the car off. It's not a belt - it sounds like air blowing over something making a buzz/squeal (like a woodwind instrument) or something like that. I've got some digging to do later today to see if I can pinpoint it, but I'm wondering if it has something to do with crankcase ventilation. I am running the black box and PCV valve connected to the IM right now, and I had Autoworks already weld up the valve cover vent that goes to the intake tube on a stock setup. I've already got the bungs on the valve cover for a catch can, and just ordered the catch can this weekend. Does anyone think by having the valve cover not vented at all (current state), it's causing pressure or vacuum or something that could be causing this noise?
*EDIT*
Just checked it again and my power steering fluid was low in the reservoir. Topped it off and hasn't done it again. I wonder if the sound was cavitation in the power steering pump. The noise is with the AC turned off, no fans running, not turning the steering wheel.
*EDIT*
#225
Pretty sure I figured out my idle issue today. I wanted to break the engine in on a stock P28 ECU, so now that that's done, I swapped in my Hondata ECU and uploaded a stock P28 map. My CEL hasn't been on, but when I connect to the ECU, it's telling me I have a Code 20 for the ELD. I've cleared it and it comes right back. This makes perfect sense as to why I would have an idle issue. I'll try to make it by the junk yard next weekend and pick up another fuse box to see if replacing that works to fix the idle issue. For now, I just increased the IACV duty cycle one notch to see if that will keep the revs from diving so low when coming off the throttle.
For the noise, I did hear it once after topping off the PS fluid, but I've driven it another 20ish miles, and haven't heard it since. My daughter rode in the back on the drive we took earlier today, and she noticed the seat was wet where the seatbelts come out. I pulled the back seat and there was a good amount of water there - the foam for the seat was soaked. I dried and cleaned everything and hosed the car down, but haven't found the water source yet. I was thinking tail lights, as I knew there was water getting in the trunk, but not sure now that I'm seeing it under the back seat.
