DaX's D16Z6 turbocharger build - older, but maybe not any wiser
#151
Re: DaX's D16Z6 turbocharger build - older, but maybe not any wiser
Whatcha payin' your pit crew in; oreos and gummy bears?!
Weather has been shitty here the last couple days and I can't pull my engine. My yard looks like a swamp. Lol! I've lost my spot in line at the machine shop because of it but he says it slows WAY down by the 2nd week anyways.
Keep up your progress, sir!!
#152
If you use that dollar tree carpet cleaner with a harbor freight steam cleaner it literally melts the dirt right off man. They are $100 at harbor freight but if you like detailing stuff out it's well worth it.
#153
Looking good Dax. I’ve been just trying to take my shop back, after I pulled the motor out it looked like a bomb had went off. lol. Welded my new shop work bench together today and getting all the assemblely parts together and ready to go. I’m guessing I’ll have the block back from CSS around January 20th-27th and I should have the head back the 2nd week of 2019. Only big ticket item left is injectors and a bigger fuel pump at this moment, everything I have should get me 500+hp
#154
#155
About halfway there on cleaning the bay. I got the rear mount installed with the bolts loose - I'm guessing with stiffer mounts, I'll need to leave it loose until I see how the T-bracket fits. Looks like it's going to be a pain to tighten at least one of the bolts. I also started looking at the core support more closely, which is bent from a prior fender bender. I may need to pull the bottom of the core support out some before I put the turbo on to make sure there is clearance for everything, as I'll be keeping AC. The driver's side / bottom of the core support is pushed in about 1.5 - 2 inches, and the passenger side is pushed in about 0.5 inches. Finally, I got the coolant adapter plug installed on the block, with a cap on it for now. This will be the feed for the coolant to the turbo.
#156
I got a feeling the rear mount is gonna be a bitch. Lol! Keep it loose and tighten down each one a little at a time, in steps, like the head studs. Where'd the coolant adapter come from again?
#158
#161
Finished cleaning the engine bay tonight. Got a before and after picture - different lighting and angles, but you get the idea - it looks waaaay better now. I should be able to hang the engine and transmission tomorrow evening.
#162
That cleaned up damn nice, I just cleaned mine up but I have years of wear and scratches from about 10 swaps and don’t look like that. Lol.
#163
I (we, rather) got the engine hung tonight. When installing the T-bracket, I remembered that the top bolt was missing when I pulled the engine out. Unfortunately I don't have a spare bolt that is the correct fit - I've got one that's too long, and one that's too short. I also noticed my T-bracket doesn't have the welded nut for the top bolt. I guess I'm going to go to the junk yard on Saturday and see if I can get a T-bracket and top bolt from another car. Oh well, I can start replacing the driver's lower ball joint and doing the front brakes over the next couple of evenings.
#166
On another note. It's tons easier to drop the engine and tranny together. When I swapped to the Z6, I couldn't get the bitch pin out of the linkage so I had to put that **** together in the bay. Yuck.. Honestly, even doing a clutch, I'd rather just pull the whole engine. Lol
#169
You guys are tripping lol. I can pull the tranny off in about 35 minutes give or take. Ac bolts work great for getting the bitch pin out.
#171
Didn't do any work tonight, but found this pic of my old setup. This was back when 300 whp was cool and we ran wastegates off the compressor housing.
#172
I discovered today that what I thought was warped rotors (from driving it before pulling the motor) turned out to be bad wheel bearings on both sides at the front. I ordered some Timken replacements, and while I've got the knuckles off, decided to replace the steering rack bellows on both sides, as the driver's side has a crack.
#173
Got most everything in the bay assembled these last 2 days. I'm sick of scrubbing dirt and mud off of stuff, though. I still lack running the small heater hose to the FITV and IACV, installing belts, the air box, and the bumper. I got my torque mounts installed and halfway filled with window weld. I'm planning to let that set to hold the center piece in the correct position, then remove them and fill the rest. I don't know any other way to do it and not glue them to the frame rails. I should be able to crank and break in the engine this coming Saturday if all goes well. I've got the knuckles off and will be dropping them off at the shop for new wheel bearings on Tuesday. I found the trunk on this car leaking pretty badly - probably need to replace the taillight seals.
#174
More progress! We should be close to startup time together. Lol!
#175
I always delete the fitv and iacv hoses. They just end up heat soaking the intake manifold and are just one more spot that could potentially leak coolant. Never had any issues with maintaining an idle that way.
