D16z6 greddy TD04H-15g kit..
Hey guys I' am new to HT and turbo world so far I'm learning a lot.. good tech stuff.. but never enough.. I have few question regarding greddy kit. Not many of HT member have this. I have the TD04H-15G on D16z6 boosting 5psi. reason I got this is because I wanted it to be CA smog legal and it was cheap.. Now I' am ready to "not smog legal" =D by eliminate the blue box (piggy back) chip my ECU tune with crome and upgrade my injectors with RC 310, also add a walbro 255 fuel pump and get a bigger DP. Just wondering what is the limit I can push this little turbo without blowing it and my motor?? What would be the HP out come?? Thanks in advance..
I notice there is a lot of members here give good advise I give to those peepz..
Re: D16z6 greddy TD04H-15g kit.. (Eggot)
the turbo i say about 250whp maybe a little less i suggest going for 220whp max and building a bottom en on the side vitara pistons and TT rods ftw
Re: D16z6 greddy TD04H-15g kit.. (KingOfQB)
regarding the greddy kit, even without the blue box and such for a d16 you will probably barely hit 200whp at 9-10 lbs of boost. plus the stock greddy kit comes with 310s you will need to get some 440s and up. but building the bottom end and top end will get you more definitely. gl
wow thats the HP range im looking forward to.. actually within a few weeks i' am going to start purchasing Vitara piston 16g 75mm, eagle rods, bearings and a spare block. hope i get atleast to 220 hp..
Re: D16z6 greddy TD04H-15g kit.. (vietfella)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietfella »</TD></TR><TR><TD CLASS="quote">regarding the greddy kit, even without the blue box and such for a d16 you will probably barely hit 200whp at 9-10 lbs of boost. plus the stock greddy kit comes with 310s you will need to get some 440s and up. but building the bottom end and top end will get you more definitely. gl</TD></TR></TABLE>
Yeah that what my friends are saying.. they keep telling me to go bigger turbo insted.. The thing with me is I want to work of what i have till not statisfied. I do have A t3/t4 turbonetics coming my way..
Thanks for the advise vietfella..
blindsk8er1013
08-31-2009 11:28 PM
