D16Y7 freshly turbo build leaking oil???????????
I had my stock d16y7 running on 7psi.. I got boost hungry and decided to rebuild it with forged internals. Eagle rods, Vitara pistons, bisi 1.2 cam, rebuilt head, and honda gaskets. The machine shop assembled the crank,rods,pistons and head. I done the 30 min break in all went well besides high oil pressure. it was 90 to 100 lbs. Later that day we started it and let it run to see what the oil pressure would do. It went to 90ish then dropped when it warmed up.. The a puddle of oil formed under the car... it was the rear main. Checked the crank and adapter plate and it was all in good shape and we thought it could have been a defective gasket. Replaced it and it still leaks. If anyone has any opinions please chime in.
Re: D16Y7 freshly turbo build leaking oil???????????
The rear main seal. Ive put it in twice, the first one with no lube and the second one with lube but we didnt remove the adapter plate the second time. It seems like it doesnt start to leak till it starts to warm up. I felt confident it wouldnt leak this time.
I dont know how it is on the d series but the fsm for a bseries states that there must be a certian amount of gap between the seal and rear plate thing. I dont know how youre installing it but are you just shoving it in till it bottoms out?
Posted from Honda-tech.com App for Android
I would open up a haynes or factory service manual for the exact specs you should set the rear main to.
I cant help you on the oil pressure deal, the oil pumps relief spring should keep the pressure in check and afaik you want 10psi per 1000rpm or better.
hatchedeg
06-29-2006 09:02 PM
doublejz
29
08-03-2005 04:44 AM
turboZChatch
11
05-23-2003 10:49 PM
