D15b Powered Sol wanna go Boost
Im have been searching everywhere for info on suggestions on wat to use n not to...but havent really gotten answers i was looking for..so check it out
Car:94' Del Sol S
Motor:D15b-no leaks or burning of oil or coolant
engine was said to have 96 k wen i got that car last May i have put on 3k since
Tranny-ex/si 3rd is taking a dump so new tranny&clutch is known replacements..
i.Wat about flywheel?
Power Wanted-200 whp safe with A/c
Powerband-Looking to start spooling at 4k till red line of 7k
Driving:Ima light foot that on occasion does a lil spirited driving..it will be babied because it will be my daily
With all that noted..I would be grateful if i could get a better insight of wat i would need to achieve this..
Car:94' Del Sol S
Re: D15b Powered Sol wanna go Boost
I have a greddy kit on my dd crx d15b7 full boost around 3.5-4k pulls hard for low boost and a 1.5L...You can make 200whp on that kit easy
official honda whore
greddy kit for a beginner like you and low boost/stock block
no need for cometic headgasket , but if you want arp headstuds i would do them with a oem y8 headgasket
ok sounds good..i have a y8 intake mani in my garage..would it have much of an affect to put it on?
i jus wanna have something reliable and quick [not lookin for fast right now] ill build a motor on tha side for that...wat are the benefits of tha arps vs oem headstuds
Many D's just can't handle the extra cylinder pressure, and the weak OEM headbolts stretch just enough. It pushes air into the coolant system, which reduces its capacity and blows coolant out of the radiator.
The Y8 HG is multilayer stainless (MLS), and with ARPs can take a lot of power - on perfectly flat block & head surfaces.
A greddy kit (with fmic added) would work for you to make 180-200whp, but a custom kit with a log manifold will be better overall, and some logs work with AC. IDK if your D15B has the deckheight of a normal D15, but if so a prefabed downpipe may hang a little low since its probably meant for a D16. A 60trim T3 with a .48ar hotside would work perfect for you. With the smaller 50trim, stock exhaust/cat, and 6psi my 8:1cr D16 made 160whp and spooled by 3300. With a bigger exhaust, it will make more power per PSI, and spool faster - but obviously louder. I use an e-cutout now, best of both worlds.
As for tuning, FL doesn't test so you can go with Crome, eCtune, Neptune, S300, etc. Just get a decent tuner, and you'll be set.
my hommie is runing 22 pounds of bost on a zc the motor last about every outher race season and a 1.5 that is the onley motor i havent blown up iv even tried so i would get eclipse turbo with turbo timer a cheap manifold and of corse turbo gages and run the **** out of it or just run about 7 to 8 psi and pull 13
my homie runs stock every thing but tires and runs 12.79
is it jdm d15b or regular d15b. There is a big difference. If you are looking for 200whp. either greddy 15g kit, or dsm turbo setup.
EG2 Aka Gun Metal
15
09-14-2008 06:17 PM
ilovejdm
08-12-2006 09:17 PM
