D series guys, need help with base map timing, ASAP...
OK guys here is the delima. We all know that when you do the obdI ecu with the OBDII dizzy you can fully advance the dizzy and only get 11* on the crank. So here is my question.
When we say base timing we are talkinga bout the idle timing (i.e. top left most cell, in my case uberdata). So do I want to set this at 13* to comensate for 1* and that will make the car run 12* like stock? What do you all have your timing at? Anyone want to share some timing maps and help a honda brotha out
charlie_sohc
08-29-2006 02:13 PM
brandond
01-16-2005 07:21 PM
GReddyB18C
09-07-2002 05:24 PM
