D-Series Guerilla Turbo Setup, Copy from Honda Tuning
Old 04-03-2003, 08:25 PM
Banned
Irishweird00's Avatar
Default D-Series Guerilla Turbo Setup, Copy from Honda Tuning
Just typed this in another post, don't know if you have seen the mag or not, or if this is a repost, but I thought I would share.
CRX Gurerilla Turbo setup, with all stock parts.. under 600 bucks at the most! Mitsubishi parts-Honda parts
1G - First Generation Eclipse 89-93
2G - Seconds Generation Eclipse 94-99
Three 2.25-inch U-bend steel - $17 each
One 2.5-inch, 90-degree aluminized bend - $25
One downpipe flange - $10
One Downpipe gasket - $8
One 1G blow-off valve flange - $10
One 1G blow-off gasket - $4
One 6-cm gasket -$3
One Turbo-to-oxygen sensor housing gasket - $5
One oil return line (you may have to widen the opening) - new $55 - used $10
One oil return gasket - $1
One silicone 2.25-inch to 2-inch reducer hose - $18
One foot of rubber 2.25-inch hose -$12-per foot
Nine 2.75-inch heavy-duty clamps - $2 each
One 3-inch heavy-duty clamp - $2.50
One 1G blow off valve - $90 new, $5 - $40 used
One 2G T25 Turbo - $25 - $150*** used
One 1G oxygen sensor housing - $10 to $20
One 2G stock intercooler core - $10 to $50
One HF CRX exhaust manifold - $20 to $50
One 60-inch long, .25-inch hard line - $1.69
One 1/8-inch NPT male-to-male fitting - $1.49
One 1/8-inch NPT female "T" fitting - $2.19
One 1/8-inch NPT male-to-1/4-inch pipe female fitting - $4.15
One 1/2-inch I.D. rubber hose, 1 foot - $1.99
One can of high-tempeture engine paint - $3.99
Four Quarts of oil - $9.16
One oil filter - $4.15
Tools you will need. If you do it yourself.
Basic mechanics tools (sockets wrenches. ect.)
Grinder
Tape messure
Center hole punch
Die Grinder Drill press/hand drill
Drill bits
2-inch hole saw
Welder
Ok that **** took forever to type, so you better ****** look at it!!!!!!!!!
Old 04-04-2003, 06:38 AM
Banned
Default Re: D-Series Guerilla Turbo Setup, Copy from Honda Tuning (Irishweird00)
haha 50 views.... not even a comment..
Old 04-04-2003, 06:45 AM
TurbodCX's Avatar
Sounds like a nice list for a budget DIY Turbo kit,
Nice work bro
Brian
Old 04-04-2003, 06:50 AM
rattletrap's Avatar
OK, I'll respond...
Very cool article. I was already planning to do this, but seeing the pics was cool.
Gonna take it one step farther and throw some B18A/B rods in there and do some ceramic coating on the piston crowns, combustion chamber, and exhaust ports. Also gonna give the Uberchip a go, if I can score the editing software as well.
Going to try to get the turbo from a 300ZX (T3 60-1, i believe), and run hard lines for all fluids.
Open to comments on this setup, if there are any opinions out there.
Old 04-04-2003, 06:54 AM
civicudesire's Avatar
in the end its going to run like **** and be all ghetto. Dude dont even waste your time because you are going to get many headaches from trying to get all that **** to work. Save money and do it right.
Old 04-04-2003, 07:19 AM
Pengo's Avatar
Default Re: D-Series Guerilla Turbo Setup, Copy from Honda Tuning (civicudesire)
ok, i dunno if its me or what or maybe i have to read the article to understand it, but i read thru the list 3 times and i'm still wondering what's being done for fuel.
Old 04-04-2003, 07:30 AM
omahaturbocivic's Avatar
Default Re: D-Series Guerilla Turbo Setup, Copy from Honda Tuning (Pengo)
I dont see any fuel system either.
Old 04-04-2003, 07:32 AM
rattletrap's Avatar
Pengo, in the article they discuss using an FMU.
civicudesire, I'm just gonna chalk your post up to a lack of knowledge on the subject.
I will agree that you have to know what to look for in order to get solid parts, but in the end you are running almost a complete Mitsu setup. In this case, using a little intelligence and common sense will save you a decent chunk of change. I guess you couldn't tell everyone that you have a greddy, Drag, revhard, etc...
I'm OK with that though...
Old 04-04-2003, 08:03 AM
Smashback's Avatar
Default Re: D-Series Guerilla Turbo Setup, Copy from Honda Tuning (rattletrap)
But getting a new or at least rebuilt turbo is worth the money. Used turbos are more trouble than they are worth and half the time you'll spend more on them than a new one...when it craps out in 5k miles and your car is billowing smoke, add the price of a rebuild to what you paid for the turbo it usually comes to more than a brand new one.
Also, the Bosch BOV is probably better than the DSM and possibly cheaper, plus all you need is a stub of pipe instead of a special flange. There's one made for Porsches that's supposed to be better than the Bosch many people use (from Volvos I think).
[Modified by Hatchblack, 5:04 PM 4/4/2003]
Old 04-04-2003, 09:53 AM
Tony Starks's Avatar
Default Re: D-Series Guerilla Turbo Setup, Copy from Honda Tuning (Hatchblack)
The best advice ever. Take it from experiance. NEVER buy a used turbo.
Old 04-04-2003, 10:02 AM
rattletrap's Avatar
Default Re: D-Series Guerilla Turbo Setup, Copy from Honda Tuning (Tony Starks)
This brings us to a question I have wanted to ask regarding turbos. I will be getting a used turbo. What is involved in bebuilding them? Are there rebuild kits/parts available to the public?
Old 04-04-2003, 10:05 AM
Banned
Yeah, thanks for telling me all the problems with this setup that I already know
I was just posting it because it looked interesting... If I was to ever build this setup I would AT LEAST buy a rebuilt turbo, and a strong manifold. BOV and fuel managment.. It's just funny how far you can go with stock parts.... Mind you this was on a OLD *** CRX stock engine...... I don't think they were planning on it lasting to long.
Old 04-04-2003, 10:13 AM
rattletrap's Avatar
Not to be argumentative, but it was a SOHC VTEC engine.
Did look beaten on though...
Old 04-04-2003, 10:16 AM
JDM EG2's Avatar
Don't get the 300zx t3. It has a weird 6 bolt exhoust housing and we could never get the but one bolt in to hold the dowpipe on. You would have to get a custom dp falnge made for it.
Go with either a saab or volvo t3 they are exactly the same. That's what I have now and it works pretty good.
Old 04-04-2003, 10:24 AM
rattletrap's Avatar
Default Re: D-Series Guerilla Turbo Setup, Copy from Honda Tuning (TurboB16Coupe)
Beautiful, appreciate that...
Old 04-04-2003, 05:27 PM
rioninja's Avatar
You talking about the pierburg bovs? Most commonly found on "Volvo 740 Intercooler" models. Me and a few people i know are all running these BOVs. Top quality piece, and adjustible.
Old 04-04-2003, 05:31 PM
New User
jinxproof99's Avatar
i have one comment..........ghetto.
Old 04-05-2003, 07:53 PM
jspek29's Avatar
pengo, the fuel is manged by a fmu, fuel mangement unit, they come in different ratio, i ordered one that was 12:1 , mean for every pound of boost u get 12 more pounds of gas or something like that,
Old 04-05-2003, 08:39 PM
BoM
BoM's Avatar
Default Re: D-Series Guerilla Turbo Setup, Copy from Honda Tuning (jspek29)
ghetto fuel system, ghetto turbo kit.
might do it to a beater, but then i'd go hondata. and that puts it over a grand.
ludeDVR
06-04-2007 02:17 PM
88crxhfb16
05-21-2005 06:46 AM
1 point 6
05-20-2003 12:42 PM
H.crx-si
04-26-2003 03:26 PM
highmilehatch
04-08-2003 07:16 PM
Quick Reply: D-Series Guerilla Turbo Setup, Copy from Honda Tuning
