curise control with new turbo setup
i have a 97 ex with curise control and just added a turbo setup to it and want to keep the curise cntrol, the thing is i change the ecu from obd2 to p28 with honda s300 with jumper harness and now the curse control dont work .. it comes on but dnt set at speeds. some one said i need to make the p28 talk with the curise control ecu , if any one has any idea about this plz help thx :)
Re: curise control with new turbo setup
I don't have any problems setting my cruise control on my 96 civic ex with obd1 z6 swap and all.
yea i have no clue why..it use to work fine with the way it was but when i put the p28 nothing happens ..it turns on and when i go to set the speed it dose nothing
do u have the electronic cruise control or vacumme controlled? Vac looks like a cylinder, the electronic looks like a box.
i think it's the vac kind, i do see vac lines hooked up to it
is any one using a p28 with there curise control that can say it works?
double check all your settings in hondata.
i looking in honda data and see nothing about curise control setings in it like on,off or what out put to use , i think honda has nothing to do with it, but i could be wrong
