CRX SS Fuel line setups...Need info/pics
I need some info regarding SS fuel line installation into the CRX.
I will be using either a STR, or GE fuel rail, Automotive regulator with earls line and fittings. I would also just like to use the Walbro intank pump if possible, with the stock tank.
- How should I run the lines?
- Is 8an with a 6an return OK for size?
- What filter would you reccomend?
- and Idea how I should connect the lines with the stock system at the tank?
- PICS PICS PICS???
Thanks for any info!
- PICS PICS PICS???
1 Post
Re: (CRX-RX)
Use the factory lines. I got some stuff from stan to switch over to a newer style filter (to remove the 2 banjo fittings) and I also got his kit to go from the filter to the rail.
Re: (XXXRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XXXRacing »</TD></TR><TR><TD CLASS="quote">Use the factory lines. I got some stuff from stan to switch over to a newer style filter (to remove the 2 banjo fittings) and I also got his kit to go from the filter to the rail. </TD></TR></TABLE>
this actually might be the best way to go!
BlueShadow
11-18-2005 08:15 AM
