crank/ oil pan.....
crank/ oil pan.....
I had a return line fitting welded in my oil pan today and i put the motor back together, well the return fitting sticks inside the oil pan maybe half of an inch and stupid effing me didn't think any thing about clearance until the car was basically finished. Now should i drawn the oil and rip the car apart again or should i be good on clearance?
d16z6
the fitting is located high up on the deep end.
d16z6
Re: crank/ oil pan..... (The Dirty EJ1)
i cant see it being a problems since you have a oil pick up and a oil guard that the pick up connects to (cant remember the name)
You'll be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2teg »</TD></TR><TR><TD CLASS="quote">a oil guard that the pick up connects to (cant remember the name)</TD></TR></TABLE>
Windage tray.
Windage tray.
Re: crank/ oil pan..... (Dartanian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian »</TD></TR><TR><TD CLASS="quote">You'll be fine.
Windage tray.</TD></TR></TABLE>
thank you!
thank you!
D16y8_619
09-08-2006 09:05 PM
