couple issues during my turbo install!!
Is my oil return line too long? Cut it some more? I can't wrap it around the Dp then it'll be too short. Either way it touches the dam dp.
Now how do I get to the 2nd bolt on the bottom row of the manifold bolts? Thats the only bolt I can't get too... And is my feedline okay?
Now with the IC
Here's the top tab, do I bolt it to the frame?
As for the bottom tabs I should just bend them up and mount them right?
Any help will be gladly appreciated.
Thanks,
'Roy
Now with the IC
Thanks,
'Roy
Re: couple issues during my turbo install!! (roydogg)
you should be ok with a 45 on the pan,on my return line i used that fire sleev on mine because it almost rests on my dp.
StolenTeg
08-24-2005 02:46 PM
