Converting a Zex Dry kit to a wet kit...need advice.
Well since my rings are going bad and I have to pull the pistons out anyways I decided to go with forged pistons. I have a Zex dry kit that's been sitting around for a while unused because it has a bad solenoid in the NMU. Here's the questions.
Does a wet kit use the NMU?
What can I re-use?
What do I need to buy?
How much $$$
OR should I just buy a new NMU and run the biggest dry shot I can?
What can I re-use?
How much $$$
Re: Converting a Zex Dry kit to a wet kit...need advice. (thehatchninja)
Don't bother. Keep it as a dry kit, much better than a single fogger wet kit, IMO.
Only way to go wet is with a direct port.
Re: Converting a Zex Dry kit to a wet kit...need advice. (RyanCivic2000)
The only wet I would consider is direct port.
Would I be able to run a 100 shot dry? I've heard that other pills work in the zex kit.
Obviously I would need larger injectors and probably a bigger fuel pump (mine now is from a B16 del sol...same as all DOHC VTEC b-series.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja »</TD></TR><TR><TD CLASS="quote">The only wet I would consider is direct port.
Yes, you can run 100 shot dry with bigger injectors and a fuel pump.
word....thanks bro...guess I'm looking for a new NMU
Anyone selling a NMU?
Double 06
06-03-2002 08:31 PM
