Converted from OBD2-OBDI with boost and now car wont start
Ok. Setup: 99 Civic Si turbo. Previously using VAFC to control 450cc injectors.
T3/T4e 50 trim, 7.5psi, 450cc injectors.
I picked up Uberdata, got the chip burner and everything, and began to chip the ECU. I am confident i soldered in all necessary resistors and chips. I burned a GSR boost map.
So I connected the ECU to the car and tried to start it. Just cranked.... so i was fiddling with the ECU plugs to make sure they were tight (which they seemed to be). Tried again, and this time it started, idle was a bit high and CEL was on. (I don't think the wiggling of the plugs had anything to do with it). I then realized my VAFC was still connected, and correcting fuel. So I turned off the car, and disconnected the VAFC.
Now the car just cranks and cranks and cranks. Sounds like its not getting spark, but I cannot verify because no one else is here to crank the car.
Can anyone point me toward what I should check for?
Thanks,
Kevin
EDIT: Also, for that short time when the car was started, (which was like 5 or 6 seconds before i killed it), the CEL was on.
Also if someone has a map for a setup similiar to this, that would be great if you could get it to me.
Thanks,
Kevin
Re: Converted from OBD2-OBDI with boost and now car wont start (turbod16y8)
Fuses are good. Because i have to get to work, i put my VAFC back in and connected the stock ECU. WOrks.
My burner is a Willem Burner if that makes a difference. But i dont think it would.
Re: Converted from OBD2-OBDI with boost and now car wont start (Poop111444)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Poop111444 »</TD></TR><TR><TD CLASS="quote">I then realized my VAFC was still connected, and correcting fuel. So I turned off the car, and disconnected the VAFC</TD></TR></TABLE>
What did you do with the MAP wire?
Poop111444
12
07-28-2004 04:02 AM
