connecting coolant lines to water cooled turbo question.
I'm making a set of coolant lines for my turbo on a 1995 Acura Integra GSR. I was thinking of getting some -6 or -4 to 1/4 pipe connectors to connect turbo side and I was going to run the stainless steel braided lines back to the back of the block, then to iacv to complete the system.
Should I use -4 or -6 lines?
What should I use to connect to block and IACV? They have small hoses coming out that you could slip the hose over and use a clamp to tighten, is that advisable? Will a clamp hold it?
civic, connect, connecting, connection, coolant, cooled, gsr, h22, honda, line, lines, tee, turbo, water, watercooled
