compression test results on fresh motor. what do you think
Old 10-10-2003, 03:05 PM
crx1856's Avatar
Default compression test results on fresh motor. what do you think
this is on my freshly done motor w/300 miles on it.
cyl #1 180 cyl#2 195 cyl#3 200 cyl#4 200. do you think i will have a problem with cyl # 1and 2, or will the rings still have time to seat? this is on a 84mm bore 9:5.1 cr in a b16.
Old 10-10-2003, 03:18 PM
bigwig's Avatar
cyl #1 is off...if you have +/- 20psi...something is "wrong"...i would call who ever did your motor and tell them...
Old 10-10-2003, 03:25 PM
m3bluegsr's Avatar
Default Re: (bigwig)
wait until a 1000 miles they could just still be sealing. Mine test showed 195 across the board with the throttle plate closed and i have 9.5 to 1 comp also. So your getting pretty good numbers.
Old 10-10-2003, 09:46 PM
crx1856's Avatar
Default Re: (m3bluegsr)
anyone else think it's could be the rings still seating or do i have a bigger problem?
Old 10-10-2003, 09:52 PM
tegasaurus's Avatar
Default Re: (crx1856)
it could be possible your headgasket hasn't sealed properly or that the rings havn't either. Like someone else said earlier, just wait till 1000 and if it doesn't change, take it back to the shop and ask them what its wrong.
DulinDragons
12-03-2009 09:05 PM
jdm.fanatic
01-10-2009 01:14 PM
B18EG6
01-29-2006 02:24 AM
RAS Motorsports
12-10-2003 05:16 AM
Quick Reply: compression test results on fresh motor. what do you think
