Complete Guide for Drag 3 Turbo Installation
#51
Re: Complete Guide for Drag 3 Turbo Installation (dasher)
just noticed....
"5) Remove the coil wire or Pgmfi fuse to prevent the engine from cranking.
6) Place oil feed line in a bucket (end which is normally connected to turbo) while other end remains connected to the engine. Crank the engine 10 times with 10 second pauses in between each attempt to fill about a quart of oil in the bucket. Now that the Oil feed line has been purged connect it to the turbo. Once connected crank the engine over 5 times to prime the turbo."
#52
Re: Complete Guide for Drag 3 Turbo Installation (integra-modder)
thanks ... edited to
"5) Remove the coil wire or Pgmfi fuse to prevent spark when priming the turbo."
I'm glad we are getting out all the typos and technicalties.... It great that I can post an article and have a couple thousand editors... keep the corrections and comments coming guys.
#53
I just used your artical to install my drag kit! Haven't started the car yet, but i appreciate your help! Thanks!
#54
Re: Complete Guide for Drag 3 Turbo Installation (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi »</TD></TR><TR><TD CLASS="quote">I just used your artical to install my drag kit! Haven't started the car yet, but i appreciate your help! Thanks! </TD></TR></TABLE>
niiiice.....
Quick Question....
Do you actually suggest redlinning the car after JUST installing the turbo? That sorta throws the theory of break-in out the door...
niiiice.....
Quick Question....
#55
Very nice write up! I'm very glad I saw this.
I'm pretty sure I'm moving to the dark side in a few months.
#58
New User
Re: Complete Guide for Drag 3 Turbo Installation (C R X)
nice !! if you post this last year i wouldnt sold my drag kit !!
the shop installed for me were bunch moneys !! after everything is finished my vtec wasnt working and pass 5k rpm i got cel code car was struggling(not enough fuel i think)..etc and they told me it's normal coz too much torque so vtec didnt come out ...BS
i waste about 7k cdn and got nothing... i was so pissed
#59
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder »</TD></TR><TR><TD CLASS="quote">
niiiice.....
Quick Question....
Do you actually suggest redlinning the car after JUST installing the turbo? That sorta throws the theory of break-in out the door...</TD></TR></TABLE>
You only need to break in a freshly built motor , not an old one which you decide to turbocharge.
And as for breaking in a freshly built motor, many guys would agree that you actually do want to have a more aggressive break-in procedure to seat the rings quickly. Their are generally 2 theories in breaking in an engine, but lets not get into that here ... do a search.
niiiice.....
Quick Question....
#60
one word to this write up.....WOW.....very very imformative and the pics are going to help my turbo install A LOT....can we sticky this??? good job bro
page 3 ownage
page 3 ownage
#61
Re: Complete Guide for Drag 3 Turbo Installation (hybrid93SIvic)
good writeup Maybe you can tack on some extra stuff..like how to install boost guages, egt guages, oilpressure guages, fuel pressure gauges, and Injectors..that would be really helpful
Khoi
Khoi
#62
Re: Complete Guide for Drag 3 Turbo Installation (Sohc Driver)
I've got a question, what did you end up doing with the Fans after the install was complete? Did you use stock fans or go with FAL slim fans?
Fantastic write-up by the way!
#63
Re: Complete Guide for Drag 3 Turbo Installation (JDM 007)
Used a Pusher style fan for the ac side and had to cut the stock radiator fan a bit on the passenger side... or you could get a slim-line fan instead.
#64
This was probably already asked before, and unless I'm blind haven't seen it.
But what do *you* recommend hooking up the vacuum lines to, in particular the BOV and the wastegate?
Source the vacuum to the booster hose?
Thanks.
Thanks.
#65
Re: Complete Guide for Drag 3 Turbo Installation (poison)
I recommend keeping things simple and clean -
use a vacuum manifold sold by Mcmastercarr and make sure you have a thick line connected to the brake booster line before the check valve. Aftermarket Intake Manifolds like the Elderbrock IM have a bung already in the end to connect a vacuum manifold to so you can leave the brake booster line alone.
By using a properly set up vacuum manifold box you can insure that all your sources receive an adequate amount of pressure and at the same time be able to check all of the connections quickly and easily from one source instead of looking all over your engine bay.
#67
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dasher »</TD></TR><TR><TD CLASS="quote">I recommend keeping things simple and clean -
By using a properly set up vacuum manifold box you can insure that all your sources receive an adequate amount of pressure and at the same time be able to check all of the connections quickly and easily from one source instead of looking all over your engine bay.</TD></TR></TABLE>
Sweet. Thanks.
Can you by chance referance where you got the vacuum box ?
Sweet. Thanks.
#68
#72
Really one of the best install tread ever, if not the best ( I didn't see them all )
you rock man!!! that is amazing in detail and quality information !!!
keep it up
Kranked
keep it up
Kranked
#73
Re: Complete Guide for Drag 3 Turbo Installation (kranked91dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kranked91dx »</TD></TR><TR><TD CLASS="quote">Really one of the best install tread ever, if not the best ( I didn't see them all )
